Results 1 to 9 of 9
    Dec 2016
    Default RNS510 Black screen
    Hi, I have RNS510 with black screen mistake, can someone help with S29AL016D dump?
    1T0035680P SW5238 HW10
    Or if possible repair mine
    Thanks in advance
    Oct 2018
    Quote Originally Posted by metoo77 View Post
    Thanks in advance
    Try this .
  3. The Following 3 Users Say Thank You to Mikle1 For This Useful Post:
    baracuda55555 (10th January, 2024), metoo77 (30th December, 2020), Papiti56 (13th February, 2024)
    Dec 2016
    tried, same problem, thanks
    Oct 2018
    have s29gl032 if you need
  6. The Following User Says Thank You to Mikle1 For This Useful Post:
    Jan 2019
    Quote Originally Posted by Mikle1 View Post
    s29GL032 it's only media.
    Firmware is in S29AL016...in this case mainbord to trash
  8. #6
    Dec 2016
    Quote Originally Posted by navserwis View Post
    I don't think that, there is someone here managed to repaire his radio by flashing also MCU.
  9. #7
    Jan 2019
    OK good lack
  10. #8
    Apr 2020
    Can I ask you to share the s29gl032 file in software version 5238.
    I have a RNS 510 HW10 SW 5238 and I only had files 3970, unfortunately to no avail (no communication setconfig, martech) only after uploading your file S29AL016 SW 5238 the navi came to life to some extent, now there is half communication (no service mode, and normal but it loads 1 stage) displays such information in the monitor (setconfig) :
    Vancouver CSL v007.007.004
    Starting Boot Loader 1...
    UUUUUUUUUUUUUUUUUUUUUUUUUUUUUUUUUUUUUUUUUUUUUUUUUU UUUUUUUUUUUUUUUUUUUUUUUUUUUUUUUUUUUUUUUUUUUUUUUUUU UUUUUUUU
    ---- RAM-INIT +: InfoLog ILstart fffc0000 ILend fffe0000 33 [ms]
    ---- RAM-INIT -: InfoLog ILstart fffe0000 ILend fffe0000 33 [ms]
    61681027 NMBH_Init - Assuming in Bootloader
    [tBoot(3):70012d1f] Found no supported device on bank 0.
    E1687011 Unable to retrieve partition /wtil
    E1681029 NMBH_Init - Abort Nand Media handler due to unavailable partition
    +++ task : startBlMain id FFDD6A88 prio 00000001
    -> BL 66 [ms] : Start Application : call BlMain()
    >BL [66 ms]:+++ task : Controll_Loop id FFDFE318 prio 0000005B
    >BL [66 ms]: p32ShPointer_SharedMemory = F0701EE0
    >BL [66 ms]:
    >BL [66 ms]:================================================= =====
    >BL [100 ms]: (c) 2005 Siemens VDO Automotive AG
    >BL [100 ms]: CP-X Platform Bootloader
    >BL [100 ms]: Version: 13.55.05
    >BL [100 ms]: Date : Sep 25 2012
    >BL [100 ms]: Time : 11:33:08
    >BL [100 ms]:THIS VERSION IS AN OFFICIAL DELIVERY
    >BL [116 ms]:================================================= =====
    >BL [116 ms]:======= Mainprint-Info =====================
    >BL [116 ms]: item len value
    >BL [116 ms]: PlatformId 00000004: 00010002
    >BL [116 ms]: ProductId 00000004: 00020101
    >BL [133 ms]: ModuleId 00000004: 00010002
    >BL [133 ms]: HardwareId 00000004: FFFFFFFF
    >BL [133 ms]: ProductionDate 00000004: 20130228
    >BL [133 ms]: Serial-Number 0000000F:
    >BL [133 ms]: A2C-Number 0000000F:
    >BL [166 ms]:================================================= =====
    >BL [166 ms]:ShowReleaseInfos
    So I think I need to write corect SW s29gl032 file.
    I will be grateful if you share
  11. The Following User Says Thank You to Bult2020 For This Useful Post:
    emconi (12th September, 2023)
  12. #9
    Jun 2013
    Lithuania, Klaipeda
    Hello, maybe You have working motherboard dumps for RNS510 3C0 035 684 Q HW: H27 SW: 5378 (NA unit)? Black screen after MRM change car model type to EU model and loading frimware version 6270
    Do i need s29gl032 ??
