Thank you.
Thank you.
I have a ecu. I opened the ecu and i see the solders of capacitor is bad. The resoldered and when i connected in the car and i try ignition, the fuse 15A break. Can you help me?
Hello guys! Great info, i read everythin, thanks. Have a question - the negative voltage (-12v) is external or is generated in the same EDU??? Do i need to connect -12v to try it on bench? Thanks.
Y have a ecu for Astra G 2001, isuzu edu end y do not know what tipe of transistor is that whit mark SMD :: SB1"". If someone help me whit any idee ??? Y think is NPN or PNP not MOSFET or two diode series maybe. Y can nop post the picture to see wher is mounted on the PCB board , is two or three pieces on the board. On the pins do not have any value.
Hello
The component look like a transistor whit 3 terminal, not whit 2 terminat like a diode. At the measure y have value like 2 jonction of bipolar transistor.
hi
or 2 diodes?
regards
cris
Just pulled my edu out and found thiscould someone tell me what component that is that's burnt out and where to buy one from.
Thanks in advance
Sent from my GT-N7105 using Tapatalk
capacitor is the same that is in good condition on the picture 10uf 35v
on a rich or poor discussion - PL & SP blood - only on bench
Hello my friends.
Finally does anyone know what is the real marking of the three IC from the picture, y have three dead ECU , oll the components is tested less than three.DSCN2221aa.JPG
Anyone do not help me whit the real name of the tree cips ???
Good morning i need pictures and explanation of how to repair ecu does not work
8971891362 (16267710
Greetings and thanks ....
14-08 0141.jpgHy my friends, if someone don't know what tipe of IC is fron the picture, is whrite on bouth 50610 or 60610, the 2 IC work to replace whit lm2904,lm358 , tested end is OK.
In one board I see LM2901, this is same chip, last 3, mini chip use from destroyed board
