Results 1 to 15 of 17
    myma7up's Avatar
    Feb 2012
    Egypt
    Default VVDI KEY TOOL MAX success and fails
    Immo Tool Data
    I have just got this new device and I will post here what is working good and what is not in the eeprom application
    and the first tow fails is
    Peugeot 206 bsi epprom 95160
    fail to read pin or immo data
    chery a113 immo micro
    hc05 mask 0l72a
    read pin ok but can not make transponder
    keep going if any one have a try
  2. The Following 2 Users Say Thank You to myma7up For This Useful Post:
    brend (7th September, 2021), mobilni (9th January, 2021)
  3. #2
    myma7up's Avatar
    Feb 2012
    Egypt
    opel immo 2 TMS370
    done read pin and generate the chip
  4. The Following User Says Thank You to myma7up For This Useful Post:
  5. #3
    myma7up's Avatar
    Feb 2012
    Egypt
    Chevrolet cruze 2012
    BCM eeprom 24c16
    read pin code ok
    chip ok ready to start engine
  6. The Following User Says Thank You to myma7up For This Useful Post:
  7. #4
    myma7up's Avatar
    Feb 2012
    Egypt
    done successfully BMW CAS 3
    0L10Y
    chip ready to start the car
  8. The Following User Says Thank You to myma7up For This Useful Post:
  9. #5
    myma7up's Avatar
    Feb 2012
    Egypt
    fail to add key to geely EC7 immo
  10. #6
    Sep 2015
    mwenge dar es salaam tanzania
    this tool failed to program key in kia sorento
  11. #7
    myma7up's Avatar
    Feb 2012
    Egypt
    Quote Originally Posted by lege View Post
    which year
    which eeprom
    93c56 or 95320
  12. #8
    myma7up's Avatar
    Feb 2012
    Egypt
    done successfully
    chery tigo 2015
    and I have got a full set for this car
    immo eeprom 24lc02
    ECU eeprom 95080
    and full ME 7.8.8
  13. #9
    aliali18's Avatar
    tunis - (kasserine*Kairouan)
    passat bcm eeprom 95320 work chip ok
    thanks digital-kaos
  14. The Following User Says Thank You to aliali18 For This Useful Post:
    myma7up (17th March, 2021)
  15. #10
    myma7up's Avatar
    Feb 2012
    Egypt
    Lightbulb
    FAIL
    Toyota corolla 2003
    3zz fe
    93c56
    the chip cant start the car
  16. #11
    myma7up's Avatar
    Feb 2012
    Egypt
    successful add new key to mazda 626 lucas 2000
    MC68HC05
    the zedfull need 8C
    and tango Fails to detect the file
    unknown vir
    realy impressed
  17. #12
    Jan 2018
    Vito mb old immobox temic hc908
    Make a start key ok
  18. The Following User Says Thank You to carmoh For This Useful Post:
    myma7up (4th April, 2021)
  19. #13
    myma7up's Avatar
    Feb 2012
    Egypt
    toyota fortuner 2013 g chip
    AKL
    reset immo with dp plus x300 obdstar
    then generate super chip with key tool max
    toyota 72G 80 bit
    3 chips
    2 master 1 sub
    but you can only prog 1 master
  20. #14
    myma7up's Avatar
    Feb 2012
    Egypt
    FAIL to do Daihatsu Terios 2004
    on super chip or on DST40
  21. #15
    Apr 2013
    FIAT pUNTO AŅO 1996 MEMORIA 93C46 TODO UN
    EXITO
