Results 1 to 7 of 7
    Oct 2016
    Default Modus DF002 problem
    Hi Everybody
    I have a problem with this EPS 8200433517 ... Error DF002 ... I have a RENAULT ECU TOOL, I did Clear DF002 and Clear immo code, I installed it in the car and ... no errors in the EPS ECU, but the STOP light is still on, the message STEERING FAULT ... Have any ideas ....
    Attached: ori and a modified dump
    Thanks for help
    baltazar3's Avatar
    Andromeda
    Quote Originally Posted by zmsautogas View Post
    Hi Everybody
    Thanks for help
    Try this and report....make coding with CLIP (config,VIN...)....pm
    '" live and learn........ if you wont ....you ain't "
    _______ . ____ . __ . __ . _______ . __ __ __ ... ---
    If my post was HELPFUL please push THANKS button
  3. The Following User Says Thank You to baltazar3 For This Useful Post:
    ugurceylan (28th October, 2022)
    baltazar3's Avatar
    Andromeda
    Any news m8 ?
  5. The Following User Says Thank You to baltazar3 For This Useful Post:
    darox2005 (9th January, 2021)
  6. #4
    Jun 2016
    EU
    Hi , any chance help with my dump , i use renault tool to modification dump , the error in module is gone , but still not work power steering , and on dash shoving fault power steering faulty that very strange ?
    Sep 2018
    Quote Originally Posted by darox2005 View Post
    Check and let me know if it works. Don't forget the thanks and reputation
  8. The Following User Says Thank You to kozik333 For This Useful Post:
  9. #6
    Jun 2016
    EU
    Quote Originally Posted by kozik333 View Post
    Work 100% ,i hope if disconnect battery still will work . Thanks a lot .
  10. #7
    Sep 2018
    Disconnect the battery and check. The engine should start. Let me know.
