THREAD CLOSED
THREAD CLOSED
HaynesPro 2025 online + AC/ Delphi 2022.02a available, message for where to get them!
abe160 (27th January, 2021), Jukica (29th October, 2021), taammm12 (12th December, 2021), TheUnknown (11th April, 2021)
I Have this same board and could not get it to work neither on usb nor on Bluetooth. I found that the FTDI chip is fake because it does not sotre the settings with Mprog 3.5 and it does not have EEprom inside as Mprog reported that no EEPROM found.
When plugged to usb it is installed as the standard FTDI driver as serial prot and not as VCI diagnostic. The driver from cd is not accepted (because it is fake ftdi with fake serial number A50285BI)
So I gave up and tried to use bluetooth because i think it will work but it did not work. The computer detected the device Autocom CDP+ BT 100953 and the pairing is ok with pin 0000, but when I try to connect to the car it says the same as with usb: the vehicle is not reponding and relay are clicking with Lights changes from blue to green and it take more than a minute to get error not responding.
3rd try: I removed the FTDI232RL from the bord hoping that may be there is a short or someting but the same relay clicking and no response.
Any advices please.
drwoong (10th January, 2021)
Yes, I hope it will work with real FTDI chip on usb. But the problem is that mine is not working on Bluetooth too with same behavior. Is the Bluetooth circuit independant from USB circuit? If yes .. why it does not work on bluetooth.?
Ok thanks bro. That is a problem for me because i can not get a real ftdi chip right now on my country
Please tell me the resutl when you will replace the chip. Thanks bro.
crouchinggerbil (10th January, 2021)
these are your best boards, especially the one with one board
crouchinggerbil (9th February, 2021)
Potential fix for those of you with one of these vci's
Use stlink ( like this: https://www.easytronics.com.br/st-link-v2 )Also take a look at this: https://www.tlemcen-electronic.com/forum...hp?t=36605
With STM32CubeProgrammer write any bin version, them write eOBD_VCI+.hex and OBD_VCI+.hex.
You can use bin files from here: https://www.digital-kaos.co.uk/forums/sh...not-FOUND)
This is how I upgraded my DS150e.
Be happy.
Credit to OP sidmoraes
karageorgos (30th June, 2022), nbtechnic (12th May, 2022)
is this autocom gold diagnostics 30250, what is obtained with this modification, I have the same, only with white nec relays and oki chip, it works well without problems.
crouchinggerbil (16th February, 2021)
Can someone tell me if my VCI is any good or bad, it works fine for my use, I'm only a diy'er and in the 18 months or so since I have bought it it has served me very well, the firmware updated just fine, and thanks to crouchinggerbil I'm running Autocom 2017 v3, and it has done all I have needed. Just curious to known if what I got is any good.
Thanks in advance!
