Results 1 to 15 of 18
    DeLuXe's Avatar
    Mar 2019
    Default RENAULT Clio II - 93C46 - 1 Key ?
    I have a RENAULT Clio II - 2000 year model with 1.2i - 8v engine.
    The cars centrallock stopped working and at the same time the car didnt want to start because it was left for to long and battery died.
    I took out the immobilizer and did see that the car only has 1 Key in the immobilizer system.
    I programmed one PCF7935 chip (overwrite) the original one (My question is, is that possible? or should I virginize the immobilizer first?)
    Tried immo off but didnt succeed that is why I thought to leave the car with original alarm system/function and program a new chip.
    Cant remember if the car had pcf7930 chip inside the key but It's a 2000 year model so I remember not seing any or I'm misstaken.
    Help please? What should I do?
    File attached.
    Thank you.
    Best regards,
    DeLuXe
    Sharing is carying. Please press Thanks + Rep Button if my post is helpful
    momogsm's Avatar
    Just Say Momo, I Will Be Here. ��
    Your BMT Is N3 Or N4, Post Please Label Information, And What You Use To Program Key And Learn Remote ? And Also Do You Have Pincode Of Your BMT ?
    Report Back
    IF I HELP YOU DO NOT FORGET TO CLICK ON THANKS AND REPUTATION
    DeLuXe's Avatar
    Mar 2019
    Sorry. BMT N3. The car wasnt here but I got ECU + BMT sent in.
    I used VVDI 2 for making PCF7935 only to try start the car. Havent tried to program the key or remote with diagnostics.
    Best regards,
    DeLuXe
    DeLuXe's Avatar
    Mar 2019
    No one with a tip?
    Best regards,
    DeLuXe
    momogsm's Avatar
    You Should Firstly Know Your Pincode, Then You Should Virgin Your BMT And Enter Pincode To BMT Then You Can Program New Blank Tronsponder, You Can Use Pcf7930/31/35,
    Then With Diagnostic Use Remote Learning Function,
    I Attached Virgin BMT For You
    Pass In Pm
    Report Back
  6. The Following 3 Users Say Thank You to momogsm For This Useful Post:
    DeLuXe (10th January, 2021), Matttes (4th March, 2021), Slav1984 (24th October, 2024)
    DeLuXe's Avatar
    Mar 2019
    Thank you so much for your information and help my friend, much appreciate and hat of for you.
    Just to my knowledge, the pincode in this car is stored in the ecu ?
    TMS 374 ?
    But with that virgin bmt file, isnt it possible to just make a new transponder and send it out to the customer to start the car?
    FVDI only have CLIO 2 from 2002-2006
    Would that work for this car from 2000? :/
    Best regards,
    DeLuXe
    Ecuprog31's Avatar
    Mar 2018
    Why you search problem when there isn’t
    just program pcf7935 and start
    and if you need more keys just copy
    fvdi doesnt help you
    for remote you can use used remote but you need to virgin your bmt and ecu
    renault ecu tool can help you
    DeLuXe's Avatar
    Mar 2019
    I tried to make new transponder but without making virgin to BMT.
    Car didnt start. I dont have Renault ECU Tool, that is my issue right now.
    I can possibly read ECU information if Its possible to unsolder and read TMS374 on table but I believe that is not possible due to other eeproms in the ECU.
    Thanks for the help.
    Best regards,
    DeLuXe
  10. #9
    DeLuXe's Avatar
    Mar 2019
    No other tool possible to use for this old car ?
    I've googled little but couldn't find anything useful :/
    Best regards,
    DeLuXe
  11. #10
    Jan 2018
    FRANCE
    Hi, you can program a T5 or 7935 with your original 93c56 dump. avdi (ori fvdi) "key tool" and "Renault clio I (-2001) ..."
    I do it with this tool and protag or MK3
  12. #11
    DeLuXe's Avatar
    Mar 2019
    I have many tools but to bad not the original avdi. Only have the FVDI clone version.
    It's little weird because car should start with either T5/7935 chip to original dump programmed on bench.
    But it doesnt. Battery was out when the car stopped responding to the original key even. Dont know what to do next :/
    Thanks for the help. If anyone have another tip or anything related then please share
    Best regards,
    DeLuXe
  13. #12
    kemaster's Avatar
    BG
    Can you post transponder logic and pin code that you get with your tool?
  14. #13
    Mar 2018
    UK
    Your original key is OK also the key that you program with the original file is OK
    The car has other problem
    for sure is not key problem
    Is the security light comes on the dash when turn the key?
    and what happens after that ? lights disappear or blink fast ?
  15. #14
    DeLuXe's Avatar
    Mar 2019
    Hi again,
    Yeah that is what I think as well. The weird thing is that the central locking remote doesnt work wich makes little confused.
    But with the 7935 chip the car should start.
    Lights disappear so no immobilizer issue it seems :/
    Best regards,
    DeLuXe
  16. #15
    Mar 2018
    UK
    Quote Originally Posted by DeLuXe View Post
    Hi again,
    Best regards,
    DeLuXe
    If some fuse is blow or plug is coroded will lost the remote and start
    So important is what happens with the security light when swith the ignition ON
    If immo lights not come solid light when switch ignition ON - That means bad connection or blow fuse
    if lights come solid and after that blink fast means that BCM has connection but can't see the key - maybe bad connection on the coil
    Also don't trust too much on their words that remote was working
