Results 1 to 7 of 7
    rob h's Avatar
    May 2011
    Default Qashqai J11 keep ignition on
    Nissan Qashqai J11 2013-2017. (rogue)
    Keyless modell , i need to turn on ignition, long ennough to write sid309.
    There are no instruction in my mms.
    Shortly after reading, it desided to turn ign off by itself.
    I kept the supply (13.8V) all the time.
    So not power saving feature, that closed ignition.
    Some suggested, keeping startbutton pressed in all the time,
    Any tips and tricks
    Greetings
    yamomoto's Avatar
    Oct 2015
    Hi.
    If I understand correctly, then maybe try like Renault (keyless model).
    Insert card, transmission into "Drive" position, press and hold "Start" button.
    The dashboard displays the "Eject card" message.
    Release "Start" button and work for 1 hour.
    BR.
  3. The Following User Says Thank You to yamomoto For This Useful Post:
    rob h (12th January, 2021)
    Aug 2008
    i was wondering same thing because j11 allways turns off while trying to do diagnostics for a while
    the renault thing might not work because there is no insert key
    the key is just sat in car ( no slot )
  5. The Following User Says Thank You to tango For This Useful Post:
  6. #4
    yamomoto's Avatar
    Oct 2015
    Stop! I'm a slowpoke!
    Recently read / write ecu Qashqai J11 2.0 CVT 2019 (23710-1HL23A).
    Starting engine, transmission to "R" or "D".
    We turn OFF engine. And turn ON the "Ignition" again.
    And we are working.
    Something like this.
  7. The Following User Says Thank You to yamomoto For This Useful Post:
  8. #5
    rob h's Avatar
    May 2011
    This is a manual transmision Car.
    However, it Will recognize the reversed Gear. And possible even the forward Gears!?
    I wil try this, and keep you guys posted.
    Thank you for your input
  9. #6
    rob h's Avatar
    May 2011
    When selected writing, i do get the instruction.
    Keep driver door open, put Car in Gear, foot on Brake and at the same time, keep start button pressed for 5 seconds
  10. The Following User Says Thank You to rob h For This Useful Post:
    tango (12th January, 2021)
  11. #7
    Aug 2008
    the car im working on is manual too so will try the above cheers rob h
