Results 1 to 12 of 12
Thread: ULoader Error
    Default ULoader Error
    Hi everyone,
    Only found the website after just 'noseying' about how to softmod a wii then took the plunge and did it from adewii and dell_xps tutorial which went pretty smoothly.
    Managed to get the first game up and running albeit during the scenes between the gaming action it was very jumpy.
    Then bought a rapidshare account and downloaded two games but both come up with 'Error from the Loader: 4'. The games titles get recognised before you press load game but then the error message comes up.
    Just got Sims Animals and that works perfectly so really puzzled
    all the games have been burned on Verbatim discs at 6x as it won't burn at 4x for some silly reason. Might try 1x though. Don't have a USB Drive as I don't go on it enough to warrant one.
    Anyone encountered that problem before, if so would really like any advice if possible.
    Thanks a lot
    V.I.P. Member ck-ok's Avatar
    nottingham
    why not try the newest neogamma http://www.digital-kaos.co.uk/forums...ma8-r17-84545/ if you still get problems it might well be your games
    OK Mate, will give it a pop, thanks.
    Must be dodgy games mate, they still don't work.
    V.I.P. Member dell_xps's Avatar
    What ULoader version are ya using m8 ?
    Change cIOS in options, try ntsc/pal option and 50 60 Hz options also m8.
    What games are giving you errors?
    Hiya m8, Mrs is on the Wii at minute, but only modded it last week so relatively new I would imagine.
    Were do you go to change the htz and cios options?
    The two games are Paper Mario and Hidden Mysteries Titanic.
    Cheers
    Quote Originally Posted by DanielParker View Post
    Cheers
    When you go into ULoader, at the bottom where you press load, to the left of that there is other options, have a play in there.
    HTH
    Junior Member stopmotion's Avatar
    Quote Originally Posted by dell_xps View Post
    HTH
    Thats How I got Zelda to Work ... I nearly binned it thinking it
    was a Dodgy Copy ... The options are there for that reason ... So I put Neogamma in Apps on the SD Card and loaded "Homebrew"
    Channel ... Went to Neogammer ... and Voila it Worked ...
    Good Luck
    Will try tonight, thanks guys.
    With the options you suggested can you play USA games then? A website listed in the Wii section of the forum is mainly US games.
    Thanks for all your help
    Tried Neogammer to launch games, changed cios and htz options in Uloader but nothing works.
    Oh well
    Solution after a lot of messing, basically don't use discs. I had a 8GB USB thumb drive so downloaded WBFS manager from a post in this forum which didn't work as it said this program is intended for 64 bit OS's even though mine was so downloaded it from WBFS Manager - Release: WBFS Manager 2.5
    Works a treat!
    Thanks for all your help, appreciate it
    nottingham
    Works a treat!
    glad you got it going
