Results 1 to 15 of 21
    rob h's Avatar
    May 2011
    Default nsuperlock Tibbe lock pick and decoder
    nsuperlock tibbe decoder
    Does anyone use this tool?
    1> one is for tibbe locks which are driven by No.1 disc. (they recomend this one for the European market)
    2>one is for tibbe locks which are driven by No.4 disc.
    Can i use it on the ignition lock, without it getting stuck?
    It appears easier to read off accurated, even on worn locks.
    super jumbe's Avatar
    Livingstone
    Quote Originally Posted by rob h View Post
    Great need a ginny pig.....
  3. The Following User Says Thank You to super jumbe For This Useful Post:
    rob h (7th February, 2021)
    p1et's Avatar
    Oct 2013
    What is that mean 'driven by disc' ?
  5. The Following User Says Thank You to p1et For This Useful Post:
  6. #4
    lion0304's Avatar
    Oct 2014
    I've bought the chinese lishi FO21, but never get any to use yet.
    This one seem like turbo decoder. Very expensive too?
  7. The Following User Says Thank You to lion0304 For This Useful Post:
  8. #5
    kemaster's Avatar
    BG
    Haven't heard for ford tibbe lock driven by No1 discs. All I've seen are by No4
    This, I assume is for door lock seeing the way it operates - tensioner at the tip
  9. The Following User Says Thank You to kemaster For This Useful Post:
  10. #6
    rob h's Avatar
    May 2011
    My guess, when they say driven by, they mean that the first cut to be in place, and to put rotation tension on.
    My guess, that would be the number4.
    I use the other Caterpillar like lishi decoder.
    That one Will get stuck in the ignition.
    And accurate reading off, allign the tool.
    Then take a picture off that.
  11. #7
    kemaster's Avatar
    BG
    Quote Originally Posted by lion0304 View Post
    As I see it's not like turbo decoder-it's tension and picking
  12. The Following 2 Users Say Thank You to kemaster For This Useful Post:
    lion0304 (7th February, 2021), rob h (7th February, 2021)
  13. #8
    Jun 2013
    Price
    125 USD including DHL.
    https://www.youtube.com/watch?app=desktop&v=V2J-NYp0IMQ
    Its not as easy, as it looks in the video.
    Also thought got the item stucked, in door lock I tested at a vehicle.
    It was just a test, on local vehicle. Not a real job.
    Got it loose after a couple of minutes. Scary!
    The old low cost Tibbe pick, was actually easier to open the door with.
    Maybe its just me needing more practice.
    Not a daily job with these locks.
  14. The Following 2 Users Say Thank You to Weasel3 For This Useful Post:
  15. #9
    Oktawian's Avatar
    Sep 2016
    All of them are stucking in ignition, hood lock and door as well. You need to have other tool to take tibbe out.
  16. The Following User Says Thank You to Oktawian For This Useful Post:
  17. #10
    rob h's Avatar
    May 2011
    I consider, making a U-shaped collor.
    To slide, down in to the lock, and make way to retract the tool.
  18. #11
    Jun 2013
    Experienced earlier long time ago, a new cut key got stuck.
    Just because I did not put it in wire brush machine.
    To remove sharp edges.
    Solution was to use a Paper Clip in the lock - And use quite much force. Took a couple of minutes. And at last I got it out.
    https://www.tiffany.co.uk/accessorie...mark-60559481/
    Wont do that again.
    Tibbe keys always in the wire brush machine. (That lesson is learned now .
  19. The Following User Says Thank You to Weasel3 For This Useful Post:
  20. #12
    rob h's Avatar
    May 2011
    I file the edges.
    The dust cap, graps the key.
    I tried a paperclip, that did not work for me.
    I will have another look, and need to try that U collar thing.
    Taling about paperclips
  21. #13
    Mar 2018
    UK
    I use tibbe on the ignition only if the ignition lock is not the same with the other locks
    I filed the edges on the position 1 so its not so easy to be stuck - if its stuck I use the pin that come with tebbe to release it in worst case I take out the ignition barrel
  22. The Following User Says Thank You to Manta1600 For This Useful Post:
  23. #14
    rob h's Avatar
    May 2011
    If you can not turn to position 1, when picking fails or a key does not turn and gets stuck:
    How to remove the lock? Do you punch the retaining pin inwards? Maybe pry outwards?
    Or does the core needs to turn to release itself.
  24. #15
    Mar 2018
    UK
    First and last time when I stuck the tibbe insde the lock and I was unable to turn it I took out the steering column and tried to open the ignition and all went faulty
    finally I bought steering column from the scrap yard and replaced
    After that I file the edges on the lishi and I decode the ignition only if is different than other locks
  25. The Following User Says Thank You to Manta1600 For This Useful Post:
