Results 1 to 12 of 12
    Jun 2018
    Netherlands
    Default Rover 45 1.8 93c66 NNN100743 immo off needed
    Hi there,
    please i need immo off ROVER 45 1.8 Petrol 2004
    93c66 NNN 100743
    many thanks in advance
    this car stays like 40km from my house, i hope someone will help me soon.....
    belgrade,serbia
    93c66 NNN 100743 off.rar try this file, tested,disconnect immo box
  3. The Following User Says Thank You to vladanr For This Useful Post:
    pietrak (24th August, 2021)
    Jun 2018
    Netherlands
    should i completely disconnect immo box ? or do it like "cut off code line pin 72 in immo box
    connect pin 23 (black - red) with the ground pin 2 (black)to allow the starter motor to work"
    belgrade,serbia
    do second solution
  6. The Following User Says Thank You to vladanr For This Useful Post:
    pietrak (9th February, 2021)
    Jun 2018
    Netherlands
    i've tried it and starter spins and motor doesn't run ;/ tested also short pin 23 with ground from car- where can be fault? what should i do more? -
  8. #6
    immokill's Avatar
    Jun 2009
    UNIVERSE
    Do you hear fuel pimp? Mate post picture of ecu pcb then I will tell you what is problem bro?
    If you have CAN chip then solution will not work .
    Here to HELP!
  9. The Following User Says Thank You to immokill For This Useful Post:
  10. #7
    Jun 2018
    Netherlands
    i didn't heard fuel pump;/
    photo's are here
  11. #8
    Dec 2018
    Default Rover immo
    My frend. Your immo off. Give thanks and password to priv
  12. The Following 2 Users Say Thank You to elektronik325 For This Useful Post:
    pietrak (15th February, 2021), VENTER031 (6th September, 2022)
  13. #9
    Jun 2018
    Netherlands
    many thanks for everyone- combination of FREE RUN eeprom + shorted ground from starter relay + remove sirene from immo box ( noisy sound ) + cut off code line in ecu helped the car is running again
  14. The Following User Says Thank You to pietrak For This Useful Post:
    danielif (1st November, 2023)
  15. #10
    Nov 2010
    could this work om NNN100682 ?
  16. #11
    Aug 2022
    PLEASE CAN I HAVE THE PASSWORD
  17. #12
    May 2023
    THANKS CANI HAVE PASSWORD
