Results 1 to 11 of 11
    Feb 2021
    Default mpps v18 program not accepted
    Hello new user here just learning the ropes as had a few issues with my car
    now i have file on it that’s wrong and not been written properly so i’ve had the file written properly and even tried a new file bit it gets to 49%
    and says program not acccepted and i have the write the original file back on anyone had this
    vw caddy 1.9 2006tia
    chrisimerk's Avatar
    Dec 2018
    England
    Quote Originally Posted by djandyk77 View Post
    Chances are bad file or bad mpps clone
    TUNING--FILE SERVICE--VMAX--EGR--DPF--FLAPS--LAMBDA--DTC--IMMO..........POSSIBILITIES ARE ENDLESS
    SPECIALISE IN TUNING DIESEL ENGINES
    (DEMON DEVELOPMENT)
    IF I HELPED YOU DONT FORGET TO HIT THANKS AND REP POSSIBILITIES ARE ENDLESS
    Feb 2021
    ok i’ve tried 3 files and cab only rewrite the original i have v12 or v13 and it’s same with that
    chrisimerk's Avatar
    Dec 2018
    England
    Post ori here and what your wanting to be done with file?
    (DEMON DEVELOPMENT)
    Feb 2021
    i just want to write new file as the original hadn’t had the bigger injectors fuelled correctly
    so have new file bit keep getting the program not accepted message
    chrisimerk's Avatar
    Dec 2018
    England
    Problem could be file if All 3 from the same person
    (DEMON DEVELOPMENT)
    Feb 2021
    it won’t let me upload it for some reason
    Feb 2021
    Quote Originally Posted by chrisimerk View Post
    3 rd file is from different person but sent original file to him too
    how cab i upload it
    chrisimerk's Avatar
    Dec 2018
    England
    how cab i upload it
    Something ain't right with files either wrong checksum or file changed out of map area
    (DEMON DEVELOPMENT)
  10. The Following User Says Thank You to chrisimerk For This Useful Post:
    djandyk77 (10th February, 2021)
  11. #10
    Feb 2021
    hi ive pm you to try send you file
  12. #11
    Feb 2021
    did it come through mate
