Hello guys , i have a problem with 2010 BMW X3 F25 2.0d Manual gearbox after carwash. When i start the engine all is ok , but when i close the driver door - DSC and ABS lights comming on , Message for Reverse light bulb , Engine shuts off , Navigation is dimming... When the engine is idling and i press lock / unlock buttons on the smart key - the result is the same. After this the car have stored next DTCS :
930732 Fault , Engine starting , During starter operation : Relay sticking
9308B0 Identification Transmitter : Undervoltage , Battery
CD9430 No message (Terminals , 0x12F) Receiver DME/DDE , Transmitter CAS , FEM , BDC
CD945D Message ( Central locking system and lid status , 0x2FC) Signal invalid
CD94B0 Message ( Longitudinal acceleration centre of gravity / lateral acceleration centre of gravity , 55.0.2) Missing receiver DME/DDE Transmitter ICM
CD94EA Message ( Actual steering angle , front axle , 57.1.2) Missing , Receiver DME/DDE
CD9519 No message (Inclination roadway / steering angle front axle effective , 56.1.2)
CD9499 No message ( Request , Wheel torque , drive train , Sum FAS , 33.1.4)
CF4420 VTG , FlexRay : Communication fault - Permanent
CF5409 No message ( Terminals , 116.0.2) Reciever VTG
440117 Transfer box (VTG) All wheel drive temporairly shut down - clutch protection
CF5489 Signal (Terminals , 116.0.2) Invalid
440102 Transfer box (VTG) Oil wear
D3541B No message (Data , Driving dynamics sensor , Expanded , 56.0.2)
D354C2 No message (Yaw rate , vehicle , 0x19F)
D354E8 No message (Actual steering angle , front axle, 57.1.2)
D35B2C No message (Longitudinal acceleration , centre of gravity , 0x199)
D35542 No message (Lateral acceleration, centre of gravity , 0x19A)
D35462 No message (Request , difference , braking torque , yaw moment , distribution , 66.1.2)
D35A57 ICM interface (Longitudinal acceleration , centre of gravity , ID:0x199) Signal invalid
D35418 No message (Status , Door sensors , secured , 0x1E1)
D3557A Signal ( Wheel torque powertrain 4 , 0x0DC
D354F8 No message (Terminals , 0x12F)
480AB8 DSC Control Unit: Vehicle start with vehicle moving or driving condition unknown
D35A53 Signal (Actual steering angle , front axle , 57.1.2) Invalid
48068C Transfer box : Temporary fault : temperature
D35577 Signal ( Wheel torque , powertrain 4, 0x0DC) Invalid
D35677 Signal (Wheel torque , powertrain 5 , 40.3.4) invalid
480689 ICM interface : Initialisation , Signal invalid
D36C8C EMF Interface ( Request hydraulic function, ID:0x260) Signal invalid
D3957A Signal (Powertrain 4 wheel torque , 0xDC) Invalid
D51C12 No message ( Setpoint , share , steering torque , driver , 68.0.2)
D51C20 No message ( Setpoint , steering torque , driver , actuator 68.0.2)
D514E8 No message (Actual steering angle , front axle , 57.1.2)
D514B8 No message (Vehicle speed , 55.3.4)
D514BE Signal (Vehicle speed , 55.3.4) invalid
030411 K-LIN_11 MFL : Wrong variant
CD0420 ZGM , FlexRay controller signalling fault
801C20 ZGM: Central fault memory Full - No control unit fault
E11458 No message (Turn signal , 0x1F6)
E114C0 No message (Status , reverse gear , 0x3B0)
B7F325 Emergency speaker : Open circuit
E1CC03 No message (Reverse gear , 0x3B0)
800E8B FRM: Terminal 30A Connection for lights faulty
E58D5E Light switch: LIN Bus, communication fault
800FC8 LIN Bus , Headlight driver module (TMS) Left : communication fault
800FC9 LIN Bus , Headlight driver module (TMS) Right : communication fault
E5EC05 Interface CAS ( Terminals , 0x12F)
CD041F ZGM: FlexRay : Line fault on path 0
D34420 DSC: FlexRay : Communication fault
482394 EPS Control unit : Initialisation fault
C9140D No message ( Terminals , 0x12F)
Any ideas are welcome! Thanks in advance.
