Results 1 to 8 of 8
    Jan 2021
    Default How to read edc15c7?
    Im trying to read edc15c7 or write ori file as ecu is stuck on programming mode,
    But cant access it using kess i get "not possible to change session"
    Mpps v18 i can get only ECU infos, but not read or write..
    Is there any solution?
    Thanks.
    Dec 2018
    Friend. Some edc15c7 have that and only the fastest to unsolder flash and read on the programmer. You have the fastest and most reliable option. Because sometimes it can spill a control summe when the processor boot does not work properly
    Jan 2021
    Quote Originally Posted by elektronik325 View Post
    Problem is that i dont have adapter of programator for that chip
    Is there any other way?
    I want to immo off as car is not starting at all and ecu is changed.
    Dec 2018
    And what kind of processor do you have in this driver? Sak167? You can try to give a 1Kohm resistor to ground and to pin 28 flash. and then try to read it.
    Inquizit0r's Avatar
    Aug 2013
    Ukraine
    Boot mode...
    dehacko's Avatar
    Feb 2018
    SK
    Desolder flash and read/write with programmer - 100work solution ( but the file does not support many software
    i try also read/write clone obd kess and mpps16 - successfull
    galleto v54 clone read well but write blocked ecu ( bad chs) - boot mode not work ( that mpp16 recovery well ecu wia booth mode, kess no)
    mpps18 works bad from old ecu edc15..
    Jan 2021
    Quote Originally Posted by dehacko View Post
    I used to read and write with galleto 54 but two chips are destroyed.
    I have used to pre-calculate checksums but still didnt worked properly now cant even access the chips at all
    Dec 2018
    No galletto has a checksum problem in Edc15. I fired the program a couple of times. The fastest way to save it, order the Sop 44 adapter and you will recover and upload it without any problems. And yes, it's a waste of time.
  9. The Following User Says Thank You to elektronik325 For This Useful Post:
    skzmaps (15th February, 2021)
