Results 1 to 15 of 19
    dirksan12's Avatar
    May 2019
    Germany
    Default HowTo: Build a low cost DIY CAN-Emulator (at least for Renault Scenic II dashes)
    While repairing my Scenic II dashboard back then, I didn't had a CAN bus emulator at hand, but this is necessary to power up the display when it's on the desk. While searching the forum, I found a post from https://www.digital-kaos.co.uk/forum...14-chipinvader who shared two CAN commands to turn the display on and off. Whereupon I posted a first version, but it could only turn on the Scenic Display. https://www.digital-kaos.co.uk/forum...=1#post3602052
    Recently I found a new post (https://www.digital-kaos.co.uk/forum...=1#post3843736 again from Chipinvader - many thanks for that!) where he published a complete test sequence.
    That was the base for the project presented here:
    A lowcost DIY CAN emulator for the Scenic II dash.
    Enhanced Version
    What you need:
    Hardware
    hw1-11.jpg click the picture to zoom in and see wiring details.
    On the MCP2515 board there is a jumper which is labeled J1. To function properly make sure it is closed so the CAN-Bus termination is enabled.
    Wireing
    PIN on Arduino PIN on MCP2515 CAN Bus Breakout Board
    D2 INT
    D10 CS
    D11 SI
    D12 SO
    D13 SCK
    5V VCC
    GND GND
    PIN (grey connector on dash)
    1 +12V
    2 GND
    29 CAN LOW
    30 CAN HI
    Software:
    The arduino project is attached to this post and can be compiled and uploaded via the Arduino IDE.
    The code which runs on the arduino is based on https://github.com/coryjfowler/MCP_CAN_lib
    A copy of this library (and the full source code for the emulator) can be found within the provided zip file. Just put the can-library into the library folder of the Arduino IDE.
    The Message-Sequence can be extended or modified by patching for the the following within the dash.ino file:
    struct msg messages[] = {
       {0x354, 8, { 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x06, 0x00}}  //0
      ,{0x35d, 8, { 0x10, 0x03, 0x20, 0x00, 0x00, 0x00, 0x50, 0x00}}  //1 dash on
      ,{0x374, 3, { 0x28, 0x02, 0x3B}}                                //2
      ,{0x743, 8, { 0x02, 0x10, 0xc0, 0x00, 0x00, 0x00, 0x00, 0x00}}  //3
      ,{0x743, 8, { 0x04, 0x30, 0x03, 0x20, 0x01, 0x00, 0x00, 0x00}}  //4 full small vfd
      ,{0x743, 8, { 0x02, 0x10, 0xc0, 0x00, 0x00, 0x00, 0x00, 0x00}}  //5
      ,{0x743, 8, { 0x04, 0x30, 0x04, 0x20, 0x0a, 0x00, 0x00, 0x00}}  //6
      ,{0x743, 8, { 0x04, 0x30, 0x04, 0x20, 0x0b, 0x00, 0x00, 0x00}}  //7 speed
      ,{0x743, 8, { 0x04, 0x30, 0x05, 0x20, 0x46, 0x00, 0x00, 0x00}}  //8
      ,{0x743, 8, { 0x04, 0x30, 0x05, 0x20, 0x44, 0x00, 0x00, 0x00}}  //9 tacho full
      ,{0x743, 8, { 0x04, 0x30, 0x01, 0x20, 0x09, 0x00, 0x00, 0x00}}  //10 tl
      ,{0x743, 8, { 0x04, 0x30, 0x01, 0x20, 0x0c, 0x00, 0x00, 0x00}}  //11 tr
      ,{0x60d, 8, { 0x00, 0x10, 0x00, 0x00, 0x27, 0x73, 0x21, 0x71}}  //12 buzzer
    for(int i=0; i<=12; i++){
          DEBUG_PRINT(i);
          if (CAN_OK != CAN.sendMsgBuf(messages[i].id, 0, messages[i].dlc, messages[i].data)){
            DEBUG_PRINT("error sending message");
          delay(3000);
    If you make your own enhancements, or you have additional CAN-Messages please post them here so everyone can benefit.
    Cheers, Dirk
  2. The Following 13 Users Say Thank You to dirksan12 For This Useful Post:
    Alfik (16th April, 2021), conan981 (23rd September, 2021), florin_leo (21st March, 2021), fuzz1 (25th April, 2021), hbalazs (15th February, 2021), Johnner (27th June, 2021), Mario Rufo (18th May, 2022), mexanico1971 (13th June, 2024), morrisgauge (28th April, 2021), okm (5th December, 2023), smayer (15th January, 2022), tszabo57 (23rd May, 2022), weddingnails (18th March, 2022)
  3. #2
    Top Poster crackintosh's Avatar
    Chisinau
    Some messages have higher period:
    Message10Id=743
    Message10DLC=8
    Message10Data=04 30 01 20 09 00 00 00
    Message10Period=1200
    Message10Comment=TL
    Message10Mode=off
    Message10TriggerId=
    your software ignore this.
    dirksan12's Avatar
    May 2019
    Germany
    Quote Originally Posted by crackintosh View Post
    Hi crackintosh,
    as far as I understood the canhack trace file syntax the period statement just defines how long to wait before the next statement is send.
    I have ignored this behaviour for the approach above. Instead I've set this to fix value (see the delay-statement within the for-loop).
    If i'm wrong please let me know.
    At the first post I have added a video now where you can see the project "in action" ;-)
    Thanks,
    Dirk
    I AM INTERESTED IN DOING ONE FOR ALOT MORE CLUSTERS IF ANYONE CAN POINT ME IN THE RIGHT DIRECTION
    dirksan12's Avatar
    May 2019
    Germany
    Quote Originally Posted by rastus86 View Post
    If you have tracelogs for those cluster at hand (smth. like this https://www.digital-kaos.co.uk/forum...=1#post3843736) this would not be a big problem.
    I could imagine to read the trace-file(s) from a sd-card directly to the arduino...
    What do you mean with "POINT ME IN THE RIGHT DIRECTION"?
    Please tell me what kind of help you would need? Please explain.
    Do you know any Can message for showing kilometers state?
    Quote Originally Posted by Alfik View Post
    I solved it :-). {0x60d, 8, { 0x08, 0x10, 0x00, 0x00, 0x32, 0xFF, 0x2f, 0x10}}
  9. The Following User Says Thank You to Alfik For This Useful Post:
    dirksan12 (18th April, 2021)
  10. #8
    dirksan12's Avatar
    May 2019
    Germany
    Hi Alfik,
    what a nice find! Thank you very much.
    How do you got that can-message? Do you have any more?
    Cheers, Dirk
  11. #9
    Aug 2016
    Bulgaria
    Hi dirk,
    My emulator is the same Arduino + MCP2515. I didn't know that there's such topic. I did my own research for the messages.
    I really like what you have made. I have tracelogs from my car, and other during indication tests.
    When I have time I will upload them.
  12. The Following User Says Thank You to kalki85 For This Useful Post:
    dirksan12 (22nd April, 2021)
  13. #10
    dirksan12's Avatar
    May 2019
    Germany
    Quote Originally Posted by kalki85 View Post
    Hi dirk,
    Hi kalki85,
    that would be awesome. I think everybody (at least those with this renault-dash that is prone to breakage) would benefit from that.
    Cheers, Dirk
  14. #11
    fuzz1's Avatar
    Jul 2019
    Makes me want to find a Renault dash and try the proposed solution. Thanks for sharing. Anyone tried for some other dash?
  15. #12
    Aug 2016
    Bulgaria
    I attach some files
  16. The Following 4 Users Say Thank You to kalki85 For This Useful Post:
    camonei (29th April, 2021), danielif (6th January, 2022), dirksan12 (29th April, 2021), klingos (23rd December, 2022)
  17. #13
    dirksan12's Avatar
    May 2019
    Germany
    Exclamation I've moved the development of the emulator code to GitHub!
    Hi there,
    for easier maintenance and further development of the DIY-CAN emulator, I have moved it to a GitHub project:
    https://github.com/dirksan28/Scenic2DashCanEmu
    The first release there contains extensive enhancements
    that have been made possible through the cooperation and contribution of
    https://www.digital-kaos.co.uk/forum...479207-kalki85 and https://www.digital-kaos.co.uk/forum...hp/98483-Alfik
    Many thanks!!!
    There is now a very large test sequence and the current mileage is also displayed when starting up.
    The best thing to do is to take a look at the current video:
    If you are in a hurry - here's the direct download link:
    https://github.com/dirksan28/Scenic2...heads/main.zip
    I would be happy if you would use the GitHub project to submit further development but also forks of the code (e.g. to support other dashes) . On the other hand we could leave discussion etc. here in this thread.
    Please contibute ;-)
    Cheers, Dirk
  18. The Following 8 Users Say Thank You to dirksan12 For This Useful Post:
    fuzz1 (24th July, 2021), GameTheoryOptimal (18th March, 2022), Jardel (4th November, 2022), Johnner (27th June, 2021), junmab (6th January, 2022), kalki85 (15th January, 2022), klingos (23rd December, 2022), tomaszcz (22nd January, 2022)
  19. #14
    dirksan12's Avatar
    May 2019
    Germany
    Lightbulb ESP32 now also supported.
    There is now also a fork that works with an ESP32 and the SN65HVD230 CAN transceiver: https://github.com/douardda/Scenic2DashCanEmu
  20. The Following User Says Thank You to dirksan12 For This Useful Post:
    fuzz1 (6th January, 2022)
  21. #15
    Aug 2016
    Bulgaria
    Great work Dirk. I'm so happy that you had time to implement my work. Thank you.
    Another task left. To light all the pixels on big display simultaneously. I think this should be available on dash versions 6 and up.
