Results 1 to 15 of 23
    Oct 2016
    Default jaguar x type 2.5 v6 no start 2002
    Hello colleagues I have a problem with this car from night to day the car does not start and I have these dtc someone can give me a hand what to do or why is this thanks and greetings
    P1638-------Can Link ECM/ABSCM Circuit / Network Malfunction
    P1260----------Immobilizer to PCM Signal Error
    Germany
    Hy my friend please try if you can to make the immo off on the ecu maybe the car will start then the problem is that you have no signal between the immo and the ecu maybe wiring or bad connection.
  3. The Following User Says Thank You to mm04kk For This Useful Post:
    garagesport (20th February, 2021)
    Germany
    the problem can also be in the dashboard
  5. The Following User Says Thank You to mm04kk For This Useful Post:
  6. #4
    Oct 2016
    Hello colleagues the board does not mark the km all stripes
    this dash carries immo
    Feb 2019
    Ukraine
    Loss of CAN. Give here a complete protocol of all blocks. Died ABS or who else ..
  8. The Following User Says Thank You to andrew1061 For This Useful Post:
  9. #6
    Oct 2016
    Hello again, some module to look at can give me an orientation that it can be apart from dash, ecu, or abs
  10. #7
    Germany
    my friend please unplug all other units like abs airbag radio and so on to see if the car will start leve only ecu and dashboard connected. I have seen many times on Ford cars that they get inside the dashboard bad connection points or bad connection at the plug . shake the dashboard a littlebit and look if the problem will go. if not open the boned there will be a fuse box or relay box or something like that look there for an big connector play a littlebit with the wires on the connector and try to start car its better when you have someone with you who start the car. if the car starts bend the pins a littlebit and problem solved
  11. The Following User Says Thank You to mm04kk For This Useful Post:
  12. #8
    Oct 2016
    colleagues is there a way to synchronize frame with ecu I have the frame out of sync or what needs to be done to encode this car
  13. #9
    alex_r_2001's Avatar
    New Jersey ,, USA
    Quote Originally Posted by garagesport View Post
    here go some diagrams ... pay close attention to com data lines there could be a module thats bad and taking the network down.....
    If I helped you dont forget press thanks and rep button
    Solidarity with Ukraine
  14. The Following User Says Thank You to alex_r_2001 For This Useful Post:
    dany3459 (5th February, 2023)
  15. #10
    electromech's Avatar
    Behind a large rock
    Struggled with one of these with P1260...it was very long ago but i recall finding the issue in the rear of vehicle it was faulty wiring at a plug...Sorry was MANY years ago so cant remember exact details...Check the Comm wiring diagram also best advise i can offer with the jag wiring is to best print it and I am sure someone from NASA compiled these wiring diagrams
  16. #11
    Behind a large rock
    Double post
  17. #12
    Oct 2016
    with which cable can I diagnose and code this car with JLR ?
    since none of the ones I have works with ford
  18. #13
    Oct 2016
    Hello again, can someone help me on this issue if the JLR cable works for this car or if someone helps me start it, I would pay to start it
  19. #14
    Sep 2013
    you can use launch to work on immobilizer. you can do ecu-dash alignment.
    Be careful because the line can pass through the climate control unit. if that is missing the car does not start.
    Turn on the ignition, the red LED next to the gear lever lights up red. after one minute it starts flashing. counts the flashes. The first slow flashes mark the first digit, while the fast flashes the second digit. For example, 1 slow blink, stop, 3 fast blinks, error number 13. Is it clear?
  20. The Following User Says Thank You to gia For This Useful Post:
    garagesport (25th February, 2021)
  21. #15
    Sep 2013
    jrl moongose don't work in this car. jlr work whit SSD software. For this car is necessary IDS software
  22. The Following User Says Thank You to gia For This Useful Post:
