hi, what are the solutions, today, to modify the VAG virtual cockpit?
install emulator ?? o in OBD
ThK
ThK
..Ecu Repair ... Steering Wheel Repair ... Dash Repair ... AirBag Repair .... that Bad LiFe ...
no information ... no news ?!![]()
only increase is possible
decrease for some vw 2015-2019 virtual dash possible by obd too![]()
no, not chinese tool. Now building up database and soon ready for the market
To my knowledge, no tools work on those dash
Master Alientech, Magicmotorsport, Autotuner, file service,
Click on Thanks and Reputation if I helped you! Thank you
please read carefully : i didn't say chinese tool but chinese cockpit !
correct ! only solution is expensive hardware replacement
each cockpit has full protected Fujitsi, and after first coding at the factory more protected !
even used cockpits can not be 100% coded anymore nor flashed, no matter what tool you use, even ODIS
database "soon" ready for market.... yeah right
maybe chinese database with "ccc" = "cheap chinese cockpits" as actually used in Golf 7
(same as those multimedia radio's from china, or iphone look-a-likes)
maybe pictures say more as words...![]()
My recommendation is to not release this solution public. As soon as it reach market, Abrites, SMOK, will steal this in 3-6 months, and after year, all shit tools will do same, and street price will drop down crazy low. Same happened with Micronas, NEC, MQB solutions. Unless it have implemented protection from cloning.
carlos666 (25th April, 2021)
I think smok is almost ready to release this solution , I watched a video of someone changing virtual dash with smok less than an hour ago on the odometer mileage correction forum FB
