Results 1 to 8 of 8
    Leeetoyo's Avatar
    Mar 2019
    Planet earth
    Default Programming battery Renault Zoe EV
    Hi guys,
    Im need to know what tool can program/marry a used EV battery pack to a Renault Zoe.
    Not much info about it as most battery pack are rental/lease.
    I suppose ori can clip should do it but would like to know if there is a passthru software that can do it?
    smirnoff_rules's Avatar
    Mar 2008
    birmingham
    are you sure it needs programming in ?
    Leeetoyo's Avatar
    Mar 2019
    Planet earth
    Not sure, but so I’ve been told.
    Mar 2008
    birmingham
    renolink has lots of options like adding chassis number
  5. The Following User Says Thank You to smirnoff_rules For This Useful Post:
    Leeetoyo (28th February, 2021)
    Leeetoyo's Avatar
    Mar 2019
    Planet earth
    That’s a start and look promising!
    Would be nice if someone can confirm that replace battery pack is possible?
    Mar 2008
    birmingham
    just replace cell no need to code anything l would say https://www.youtube.com/watch?v=YU_qfD582Sk
    Leeetoyo's Avatar
    Mar 2019
    Planet earth
    The plan is to buy a Renault Zoe without a battery and buy a battery pack from scrap yard.
    Otherwise cell replacement would be an option but not in my case..
    Aug 2008
    good luck finding a battery pack,cant find one anywhere cheap (scrap yards still expensive, seen them still wanting £5000)
    you can take a battery pack from one zoe ze and put onto another zoe ze with no problems at all
    car will run ok (done it just to proove it can be done)
    not sure about the milage side tho because when on non paired car the milage range went to about 90 ish but back in original car range is 116 miles
  10. The Following User Says Thank You to tango For This Useful Post:
    Leeetoyo (1st March, 2021)
