Results 1 to 15 of 26
Thread: Carminat TomTom
    Arrow Carminat TomTom
    Hi all,
    I have new Renault Grand Scenic 2010,
    Car is equipped with Carminat TomTom Navigation system with 2GB SD Card (not DVD version).
    I have try to buy maps thru TomTom Home but it is impossible from my location.
    Can anybody help me with what ever is called, patching, cracking and downloading appropriate maps for mentioned device.
    I am not experienced in this so I kindly ask for detailed explanations.
    Thanks in advance
    xant14's Avatar
    Mental Mowbray
    What map have you got? and what map are you after? you have a 2010 model motor? hardly likely to be a newer map available... is there?
    Thanks for your quick reply.
    Installed map is 840.2568 Eastern_Europe.
    Navcore is 8.841
    I need map for Western Europe or for whole Europe
    As explained I try to buy and download maps, cost 50 EUR at TomTom but it is not possible from my location.
    TomTom support says they dont have partner on my location and therefore can not accept my cradit card
    Any solution
    xant14's Avatar
    Mental Mowbray
    Ah, see if this link works, this is Western & Central Europe 840.2562 the one with ALG and EQ routes.
    Western_and_Central_Europe_840_2562 by Protect My Links . Com
    you will need a 4 gb card because this is just over 2 gb.
    You then need to crack the map before it will work
    to crack the map you need
    1 the map Western_and_Central_Europe_840_2562 by Protect My Links . Com
    2 the keygen. Digital Kaos - Downloads - Easy use tools
    3 meta.txt file here Digital Kaos - Downloads - meta.txt
  5. The Following User Says Thank You to xant14 For This Useful Post:
    Hi again,
    You are VERY helpful on this and I thank you very much.
    I have 4GB SDHC card and will download files you told me.
    Can you please send step by step instruction how to patch or crack. I am not experienced in this.
    Thanks in advance
    xant14's Avatar
    Mental Mowbray
    Well the good thing is your navcore is good to go with the new maps, most people have to upgrade this for the maps to work.
    The bad news is, I have never used easyusetools, so I cant help ya much.
    I crack my maps using command prompt, I need to write up a guide, as best I can to be able to post it. But I haven't done that yet.
    good news is, you have all the files required, and running easyuse tools should be straight forward, you just enter the files, and info that it requests. You will need your device id too. a ten digit code looks like this AQ2TH ASDFR
    When you enter this, make sure you DO NOT put a space between the characters.
    This info is for tomtom standalone units, I am assuming the in built is the same. You only need crack the map, so all this can be done in a card reader.
    I will try look out for a tut for easyuse tools. good luck.
    Please check following link, maybe you understand this better that I do.
    http://www.gpsunderground.com/forums...ad.php?t=10423
    xant14's Avatar
    Mental Mowbray
    Alright integra... the first thing, I am assuming your gps is the same as any other tomtom, I have never seen the inbuilt ones of Renault, but looking at the navcore , it seems to follow suit.
    second.. your navcore, 8.841, should be good to for any map, but I have never seen that version before. so the only thing you need to crack is the map..
    as i said to crack the map you need
    you also need your device id, the 10 digit ABCDE FGH2J This can be be found in your tomtom by pressing sat signal, then navcore ,
    then go about cracking the map on a fresh card, in your card reader.. just follow what easy use tools asks you for.
  10. #9
    Thanks,
    I am on way to patch this, learning slow because all is new for me. It seems that 840_2562 maps are not good for my device. I must use 840_2563 or 840_2568 which I found. Please check http://www.gpsunderground.com/forums...ad.php?t=13987
  11. #10
    xant14's Avatar
    Mental Mowbray
    Ahh, I didn't realise the map would be no good. That chart does not show your navcore version. I can only assume that the carminat (Renault) version is different in some way. Sorry but I know nothing about it.
    Do be careful about changing navcores and bootloaders. I would hate to see you brick your device. I was hoping that just downloading a map, and cracking the map it would work on your sat nav.
    Looking at your original map, I would download Europe_2GB_840_2568 (1.72 GB) and just crack that.
  12. #11
    Smile Megane 2009
    Will it also work on a Megane 2009 version ??
  13. #12
    has anybody tried this already and seen if it works?
  14. #13
    any one got feedback yet if its working...?
    I have the Benelux and looking for eiter Europe or France
  15. #14
    Also very interested in maps of europe for the builtin carminat tomtom. anybody who has got it working??
  16. #15
    Will this work on a Laguna 2010?
    Just download the map, activate it and hit the road?
    If the answer is yes... So cool! Thanks in advance.
