Results 1 to 15 of 18
    Default Ford Focus 1.8 Tddi Fuel pump timing??
    Hi Folks, Newbie here, got a huge problem and really hope someone can help!! Got a V reg 1.8 Tddi Ford Focus and am in the middle of trying to change the injection pump. Trouble is, I didn't time it all up before I took it apart and now I'm struggling to time it back up!! I've managed to locate and lock TDC on the Crank and Camshaft, the trouble is can't see any way of locating the pulley to the fuel pump in the correct position. There is a key way in the end of the pump, but no corresponding key in the pulley! I know that I have to locate the pulley with a 6mm drill bit once it's on but don't know where to tighten it in the first place....AAAAARGH!! Any help greatly appreciated
    Is it common rail??
    DK Veteran teuton's Avatar
    Mexico
    You'll find it in Autodata. Just attached the pic, sorry text is not in english.HTH.
    Yesterday we stood in front of the abyss. Today we'll move ahead.
    If you need any repair manual, pm me- maybe I can help you.
    No, it's not common rail, also thanks for the autodata stuff, I've already got that but it doesn't help when the pulley and pulley carrier is removed from the pump. Thanks anyway tho!
    Mexico
    So take a look at this mate. HTH.
    Staffs UK
    As far as ETIS is concerned, it says that the inner pulley is part of the pump assy when replacing the pump.
    So if you have "lost" the timing to the pump shaft I think you might have to go to a pump specialist to re-time it before you fit the pump back to the engine
    Staffs UK
    sorry for the double post
    news flash:
    the pump may be delivered in a "locked" condition, where the pump shaft is locked by a hexagon bolt and after fitting, the bolt is removed and either fitted with a spacer or replaced with a shorter socket head.
    It is presumably locked in the right position to pin the pulley carrier to the pump body.
    Locate the locking bolt and re-time the assy?
    Junior Member dizil's Avatar
    Jun 2009
    Ukraine
    After the start of engine verification of corner of passing of injection (impulses of management the valve of passing) the equipment of Ford IDS(WDS) is needed.
    Quote Originally Posted by teuton View Post
    So take a look at this mate ok
    Oct 2010
    Morocco
    My Ford focus 1.8 tddi doesn't start anymore, it is a pump injector problem.
    The pump was replaced by another one which have the same reference ... 40006 but the problem persist.
    Could someone send me the repair manual for the pump injector bosch vp30 so i can repair my original pump ?
    regards and sorry for my english
    DK Veteran dik's Avatar
    Apr 2009
    In a mental institution
    Quote Originally Posted by driveryosef View Post
    There is a very useful SEARCH feature found on all forums, I used it for you http://www.digital-kaos.co.uk/forums...olution-73680/
    another happy customer
    Sent from my keyboard using fingers to type
    If you have installed a second hand pump you will have to get it programmed due to the PATS system ford use.
  13. #13
    DK Veteran Poptest's Avatar
    Sep 2010
    Quote Originally Posted by nutloose View Post
    Nutloose is correct. Timing has been lost when drive coupling was separated from the pump shaft.
    This can only be retimed by a Bosch diesel workshop which has the eps815 and vp44 test accessories.
  14. #14
    Oct 2010
    Morocco
    Quote Originally Posted by dik View Post
    Thank you for your help,
    I now "SHEARCH" but i'm new on the forum and i don't have right privilege to download or see documents !
    Regards,
  15. #15
    Oct 2010
    Morocco
    hello all,
    can someone inform me about :
    can I replace just the electonic box of my pump without reprogramming the ECU ?
    thanks in advance
