Results 1 to 3 of 3
    Mar 2021
    Earth
    Default RenOLink manual, and instructions
    RenOLink Manual and Instructions
    Here is a link of a English manual for the RenOLink device.
    I will be uploading more instruction manuals in the near future, and I have not yet uploaded unedited manuals yet.
    You will find the manual and other instructional media here:
    https://mega.nz/folder/4kpSTQST#3Hj5vdm5_bImWcf_JjE9eQ
    Please feel free to request help, or to request specific manuals.
    RenOLink Information (renolink-europe.com)
    Product Functions
    1. RenoLink allows you to perform the following operations on Renault and Dacia:
    Reading of fault codes for all systems (engine, transmission, ABS, AirBag, electronics, etc.)
    Clearing of fault codes
    Lights off on the vehicle dashboard
    Reset maintenance / oil service reset
    Real-time reading of vehicle parameters (temperatures, pressures, sensors, ...)
    Reading of PIN or ISK code
    • Reset the power steering ECU
    • Programming / coding of injectors
    • Programming / coding of keys
    Airbag ECU reset
    Flash calculator
    • And many other possibilities
    2. In addition, this diagnostic pack allows you to perform engine diagnostics on all brand of vehicle. (Audi, BMW, Peugeot, Citro๋n, Renault, Volkswagen, Ford, Nissan, Toyota, Kia, Chevrolet, Seat, Volvo, Land Rover, ...)
    You will be able to do the following:
    Reading of motor error codes
    Clearing engine error codes
    Removal of the engine warning light on the dashboard
    Real-time reading of vehicle parameters (temperatures, probes, sensors, pressures, ...)
    Important: only the engine ECU diagnosis is possible in multi-brands.
    Vehicle Compatibility
    For standard multi-brand diagnosis, OBDLink SX USB is compatible with the following vehicles:
    • All GASOLINE vehicles from 2001-2002
    • All DIESEL vehicles from 2004-2005
    • All UTILITY and GPL vehicles from 2007
    Windows Compatibility
    OBDLink SX USB and RenoLink are compatible with all Windows versions in 32 or 64 bit.
    Not compatible on Mac OS.
  2. The Following 12 Users Say Thank You to Autotronics76 For This Useful Post:
    aqemqum10 (22nd June, 2021), benjarray (27th July, 2023), brodaty (2nd May, 2021), Dunker (13th March, 2021), jmac200t (24th January, 2022), just4upal (13th March, 2021), MarekP (11th March, 2021), RedNix (12th March, 2021), Robinjo (20th March, 2021), smokinjoe (6th February, 2022), torzet (13th March, 2021), wojtech (11th March, 2021)
  3. #2
    Jan 2022
    Quote Originally Posted by Autotronics76 View Post
    Product Functions
    • Reading of fault codes for all systems (engine, transmission, ABS, AirBag, electronics, etc.)
    • Clearing of fault codes
    • Lights off on the vehicle dashboard
    • Reset maintenance / oil service reset
    • Real-time reading of vehicle parameters (temperatures, pressures, sensors, ...)
    • Reading of PIN or ISK code
    • Airbag ECU reset
    • Flash calculator
    • Reading of motor error codes
    • Clearing engine error codes
    • Removal of the engine warning light on the dashboard
    • Real-time reading of vehicle parameters (temperatures, probes, sensors, pressures, ...)
    At the moment, the mega.nz link lead to an empty folder. Consequently still no manual nor instruction
  4. The Following 3 Users Say Thank You to pinuche0706 For This Useful Post:
    albertros (22nd January, 2022), ohtmaneo (23rd March, 2022), smokinjoe (6th February, 2022)
  5. #3
    Jun 2021
    thanks but it is an empty folder
