Greetings,
Wanted calculate PIN from COO7 eeprom dump.
Greetings,
No pin in the dump! Is COO locked ?
I don't know about coo7 lock, ECU is burned . Before this TRUCK was working fine.
I need PIN to marry new ECU with old COO7.
If COO is unlocked , the encryption and pin code missing in eeprom dump. I don`t see codes in your dump - check COO status : unlocked/locked.
Hello
Here is other coo7 dump , are you see PIN ?
yotrans (6th August, 2021)
I don't see PIN . Do you check is the coordinator locked ?
Here is coo sops ,please tell where i see it?
SOPS file doesn't contain that info - inside no pins/keys and no lock status . Must check via diagnose SDP3 - is the coordinator locked or unlocked. If is locked then is possible to extract PIN from eeprom dump.
Here is coo7 screenshot from SDP3, but without ECU impossible to understand locked or unlocked.
you can use this tool from diagcode.com
Meat-Head (16th August, 2021)
Here is locked coo7.
Strange , my coo7 has unknow status in SDP3 without EMS on table.
Calibration window is empty.
hi , how to get it please i need it .
>>> If I helped you please press Thanks and Rep. - Password only by PM <<<
Bllinda (19th July, 2021), Dzeepromer (26th August, 2021), Meat-Head (16th August, 2021), WesleyMussum (29th March, 2022)
