Results 1 to 1 of 1
    EnCoders's Avatar
    Mar 2021
    Default MB Actros / Axor / Atego Euro-6 Continental MCM ECU codes list
    here is a codes from MCM unit of Euro-6 Mercedes trucks with Continental controller.
    Most of them should be repaired and only SCR (nox, urea), DPF / DOC and EGR related can be disabled with some mechanical part of work.
    00F0EE - MU_EGR_OBD_1
    01F0EE - MU_EGR_OBD_2
    02F0EE - MU_EGR_OBD_3
    03F0EE - MU_EGR_OBD_4
    040E03 - Ether Start, Shorted to Ground
    040E04 - Ether Start, Shorted to Battery
    040E05 - Ether Start, Open Load
    04F0EE - MU_EGR_OBD_5
    05F0EE - MU_OBD_PROTO_EV_1
    06F0EE - MU_OBD_PROTO_EV_2
    07F0EE - MU_OBD_PROTO_EV_3
    080201 - MU_EBM_BRAKE_MALFUNCTION
    080212 - MU_EBM_RED_BRAKE_POWER
    08F0EE - MU_OBD_PROTO_EV_4
    09F0EE - MU_OBD_PROTO_EV_5
    0AF0E3 - Intake Throttle Valve Circuit Failed High
    0AF0E4 - Intake Throttle Valve Circuit Failed Low
    0AF0E5 - Intake Throttle Valve Circuit Failed Open
    0B020D - J1939 Transmission Current Gear Signal is missing
    0B0213 - J1939 Transmission Current Gear Signal is erratic
    0BF0E3 - H Bridge 1 Circiut Shorted to Battery
    0BF0E4 - H Bridge 1 Circuit Shorted to Ground
    0BF0E5 - H Bridge 1 Circuit Open Load
    0BF0EE - H Bridge 1 Circuit Open Load
    0CF0E3 - MU_ISP_T_TBD4_SRH
    0CF0E4 - MU_ISP_T_TBD4_SRL
    0D0E03 - Proportional Valve Bank 1 Circuit Failed High
    0D0E04 - Proportional Valve Bank 1 Circuit Failed Low
    0D0E06 - Current Flow on HS1 IM1 Too High
    0DF0E3 - Thermal Switch Circuit Failed High
    0DF0E4 - Thermal Switch Circuit Failed Low
    0E0E03 - Proportional Valve Bank 2 Circuit Failed High
    0E0E04 - Proportional Valve Bank 2 Circuit Failed Low
    0EF0E3 - MU_ISP_T_TBD3_SRH
    0EF0E4 - MU_ISP_T_TBD3_SRL
    0F0E03 - MCM Internal Injector Power Supply Failed High
    0F0E04 - MCM Internal Injector Power Supply Failed Low
    0FF0E3 - Function 8 Circuit Failed High
    0FF0E4 - Function 8 Circuit Failed Low
    0FF0E5 - Function 8 Circuit Failed Open - 10F0E3 - Component Y630 (Gegendruckventil Turbocompound-Einheit) has a short circuit to positive.
    10F0E4 - Component Y630 (Gegendruckventil Turbocompound-Einheit) has a short circuit to ground.
    10F0E5 - Component Y630 (Gegendruckventil Turbocompound-Einheit) has an open circuit.
    110B02 - Der Status der Feststellbremse ist unplausibel
    11F0E3 - Turbo Brake Sleeve Circuit Failed High
    11F0E4 - Turbo Brake Sleeve Circuit Failed Low
    11F0E5 - Turbo Brake Sleeve Circuit Failed Open
    12F0E3 - Function 19 Circuit Failed High
    12F0E4 - Function 19 Circuit Failed Low
    12F0E5 - Function 19 Circuit Failed Open
    13F0E3 - Service Push Button Circuit Failed High
    14F0EE - Pressure Limiting Valve, Failed to Close
    15F0E3 - Compressor Differential Pressure Outlet Failed High
    15F0E4 - Compressor Differential Pressure Outlet Failed Low
    16F0E3 - Function 22 Circuit Failed High
    16F0E4 - Function 22 Circuit Failed Low
    16F0E5 - Function 22 Circuit Failed Open
    17F0E3 - Component Water pump has a short circuit to positive.
    17F0E4 - Component Water pump has a short circuit to ground.
    17F0E5 - Component Water pump has an open circuit.
    18F0E3 - Function 25 Circuit Failed High
    18F0E4 - Function 25 Circuit Failed Low
    18F0E5 - Function 25 Circuit Failed Open
    190E02 - DPF Inlet Pressure Sensor Drifted High In Range Fault (High Box)
    190E03 - The signal voltage of component 17B11: Exhaust pressure sensor upstream of diesel particulate filter (DPF) is too high.
    190E04 - The signal voltage of component 17B11: Exhaust pressure sensor upstream of diesel particulate filter (DPF) is too low.
    190E08 - DPF Inlet Temperature, Signal Spike
    190E0A - DPF Inlet Pressure Sensor Stuck
    190E14 - DPF Inlet Pressure Sensor Drifted High In Range Fault (Low Box)
    190E15 - DPF Inlet Pressure Sensor Drifted Low In Range Fault (Low Box)
    190E1F - DPF Inlet Pressure Sensor Drifted Low In Range Fault (High Box)
    19F0E3 - RCP Test Function 1 Circuit Failed High
    19F0E4 - RCP Test Function 1 Circuit Failed Low
    19F0E5 - RCP Test Function 1 Circuit Failed Open
    1A0E00 - DPF System Back Pressure Too High
    1A0E02 - DPF Pressure Sensors - Plausibility Error
    1A0E03 - The signal voltage of component 17B12: Exhaust pressure sensor downstream of diesel particulate filter (DPF) is too high.
    1A0E04 - The signal voltage of component 17B12: Exhaust pressure sensor downstream of diesel particulate filter (DPF) is too low.
    1A0E0A - DPF Outlet Pressure Sensor Stuck
    1A0E0E - DPF Outlet Pressure Sensor Drifted High In Range Fault (High Box)
    1A0E14 - DPF Outlet Pressure Sensor Drifted High In Range Fault (Low Box)
    1A0E15 - DPF Outlet Pressure Sensor Drifted Low In Range Fault (Low Box)
    1A0E1F - DPF Outlet Pressure Sensor Drifted Low In Range Fault (High Box)
    1AF0E3 - RCP Test Function 2 Circuit Failed High
    1AF0E4 - RCP Test Function 2 Circuit Failed Low
    1AF0E5 - RCP Test Function 2 Circuit Failed Open
    1B0000 - EGR Valve Position Feedback Failed (High Box)
    1B0001 - EGR Valve Position Feedback Failed (Low Box)
    1B0002 - EGR Valve Position Feedback Failed
    1B0003 - EGR Valve Position Circuit Failed High
    1B0004 - EGR Valve Position Circuit Failed Low
    1B0007 - EGR Valve Stuck Open
    1B000E - EGR Valve Position Positive Torque Error
    1B0013 - Smart Actuator Indicates EGR Position Error
    1B060E - FSG: Detect unwanted ECU change
    1BF0E3 - Volute Control Valve, Shorted to Battery
    1BF0E4 - Volute Control Valve, Shorted to Ground
    1BF0E5 - Volute Control Valve, Open Load
    1CF0E3 - Volute Shut Off Valve, Shorted to Battery
    1CF0E4 - Volute Shut Off Valve, Shorted to Ground
    1CF0E5 - Volute Shut Off Valve, Open Load
    1DF0E3 - Variable Camshaft Phase, Shorted to Battery
    1DF0E4 - Variable Camshaft Phase, Shorted to Ground
    1DF0E5 - Variable Camshaft Phase, Open Load
    1E0D03 - EGR Pressure Failed High
    1E0D04 - EGR Pressure Failed Low
    1EF0E3 - Function 31 Circuit Failed High
    1EF0E4 - Function 31 Circuit Failed Low
    1EF0E5 - Function 31 Circuit Failed Open - 20F0E3 - Multiplexer 1 Channel 2, Shorted High
    21F0E3 - Multiplexer 2 Channel 1, Shorted High
    22F0E3 - Multiplexer 2 Channel 2, Shorted High
    230D03 - Urea Tank Heater Circuit Failed High
    230D04 - Urea Tank Heater Circuit Failed Low
    230D05 - Urea Tank Heater Circuit Failed Open
    23F0E3 - Multiplexer 3 Channel 1, Shorted High
    24F0E3 - Multiplexer 3 Channel 2, Shorted High
    25F0E7 - Smart Remote Actuator 2, Failsafe Mode, Motor On
    25F0E8 - Smart Remote Actuator 2, Internal Test Running
    25F0E9 - Smart Remote Actuator 2, Failsafe Mode, Motor Off
    25F0EB - Smart Remote Actuator 2, Restricted Operability
    25F0EE - Smart Remote Actuator 2, No Failsafe Mode, Motor Off
    25F0EF - Smart Remote Actuator 2, Temperature Warning
    25F0F0 - Smart Remote Actuator 2, Temperature Fault
    25F0FF - Smart Remote Actuator 2, Unknown Error Code
    26F0ED - Turbocharger Compressor Outlet Differential Pressure Sensor Out Of Calibration
    26F0EE - Turbocharger Compressor Outlet Differential Pressure Sensor Out Of Calibration
    27F0F0 - MU_EPC_POW_TOLERANCE_SRH
    27F0F2 - MU_EPC_POW_TOLERANCE_SRL
    28F0F0 - Fuel Quantity High Detected
    28F0F2 - Fuel Quantity Low Detected
    2A050E - Multiple Cylinder Misfire Detecetd
    2A051F - MU_ISC_MUL_MISFIRE_AT_IDLE
    2A1503 - Quantity Control Valve (Low Side) Error
    2A1504 - Quantity Control Valve (High Side) Error
    2B050B - Cylinder 1 Misfire detected
    2B050E - MU_ISC_CYL1_SRL
    2B051F - Verbrennungsaussetzer des Zylinders 1 wurde erkannt.
    2C050B - Cylinder 2 Misfire detected
    2C050E - MU_ISC_CYL2_SRL
    2C051F - Verbrennungsaussetzer des Zylinders 2 wurde erkannt.
    2CF0EE - MU_IS1_SPOR_DEF_1
    2CF0FF - MU_IS1_SPOR_DEF_2
    2D050B - Cylinder 3 Misfire detected
    2D050E - MU_ISC_CYL3_SRL
    2D051F - Verbrennungsaussetzer des Zylinders 3 wurde erkannt.
    2DF0E2 - MU_AM_VCP_POS_DEV
    2DF0E7 - MU_AM_VCP_CLAMP
    2DF0EA - MU_AM_VCP_SLOW_RESPONSE
    2DF0EE - Turbocharger Compressor Inlet Differential Pressure Sampling Range Failure
    2DF0FF - MU_AM_VCP_JOG_FAIL
    2E050B - Cylinder 4 Misfire detected
    2E050E - MU_ISC_CYL4_SRL
    2E051F - Verbrennungsaussetzer des Zylinders 4 wurde erkannt.
    2EF0E0 - MU_AM_VCP_TEMP_IND_HIGH
    2EF0EE - DPF Zone 3 Condition
    2EF0FF - DPF Zone 2 Condition
    2F0403 - Component 15Y32: Engine cooling system viscous clutch solenoid valve has a short circuit to positive.
    2F0404 - Component 15Y32: Engine cooling system viscous clutch solenoid valve has a short circuit to ground.
    2F0405 - Component 15Y32: Engine cooling system viscous clutch solenoid valve has an open circuit.
    2F050B - Cylinder 5 Misfire detected
    2F050E - MU_ISC_CYL5_SRL
    2F051F - Verbrennungsaussetzer des Zylinders 5 wurde erkannt.
    2FF0EE - EGR System Parametrization Failure
    2FF0FF - DPF System Parametrization Failure
    300403 - Component 10Y01: Engine brake 1 solenoid valve has a short circuit to positive.
    300404 - Component 10Y01: Engine brake 1 solenoid valve has a short circuit to ground.
    300405 - Component 10Y01: Engine brake 1 solenoid valve has an open circuit.
    30050B - Cylinder 6 Misfire Detected
    30050E - MU_ISC_CYL6_SRL
    30051F - Verbrennungsaussetzer des Zylinders 6 wurde erkannt.
    30F0E8 - MU_IS4_SPOR_DEF_1
    310403 - Component 10Y02: Engine brake 2 solenoid valve has a short circuit to positive.
    310404 - Component 10Y02: Engine brake 2 solenoid valve has a short circuit to ground.
    310405 - Component 10Y02: Engine brake 2 solenoid valve has an open circuit.
    31050B - Cylinder 7 Misfire Detected
    31050E - MU_ISC_CYL7_SRL
    31051F - Verbrennungsaussetzer des Zylinders 7 wurde erkannt.
    31F0E8 - MU_IS4_SPOR_DEF_2
    32050B - Cylinder 8 Misfire Detected
    32050E - MU_ISC_CYL8_SRL
    32051F - Verbrennungsaussetzer des Zylinders 8 wurde erkannt.
    32F0E2 - MU_EGCP_DIA_TTIP_ADJ
    32F0E3 - MU_EGCP_DIA_SC_ERR
    32F0E5 - MU_EGCP_DIA_OC_VN
    32F0EE - MU_EGCP_DIA_SENS_DEF
    330000 - Intake Air Throttle Position High
    330001 - Intake Air Throttle Position Low
    330002 - Intake Throttle Position Deviation Error
    330003 - The signal voltage of component 10Y26: Throttle valve is too high.
    330004 - The signal voltage of component 10Y26: Throttle valve is too low.
    330007 - Intake Throttle Auto Calibration Error
    33F0E5 - MU_EGCP_DIA_OC_VG
    33F0E9 - MU_EGCP_DIA_SPI_WR_ERR
    33F0EB - MU_EGCP_DIA_SPI_INI_ERR
    34F0E5 - MU_EGCP_DIA_OC_VIP
    350405 - Der Stromwert des Bauteils Y634 (Mengenregelventil Rail) ist zu niedrig.
    350406 - Die Stromregelung des Bauteils Y634 (Mengenregelventil Rail) hat eine Funktionsstorung.
    350407 - Der Soll-Raildruck wird nicht erreicht.
    35040E - Die Leckage im Hochdruckregelkreis ist zu hoch.
    35040F - Der Soll-Raildruck wird nicht erreicht.
    35041F - Rail pressure regulation has a malfunction.Der Soll-Raildruck wird nicht erreicht.
    35F0E5 - MU_EGCP_DIA_OC_VRC
    36F0E0 - MU_PBS_INTERNAL_ERROR
    36F0E1 - MU_PBS_CRITICAL_ERROR
    36F0E2 - MU_PBS_AIR_SUPPLY_ERR
    36F0E3 - MU_PBS_U_BAT_HIGH
    36F0E4 - MU_PBS_U_BAT_LOW
    36F0E7 - MU_PBS_VALVE_SUPPLY
    36F0E9 - MU_PBS_CAN_ERROR
    36F0EB - MU_PBS_GENERAL_ERROR
    36F0EE - MU_PBS_PWR_SUPPLY
    36F0EF - MU_PBS_TEMP_ERROR
    36F0F0 - MU_PBS_PAR_ERROR
    38F0E0 - tbd
    38F0E1 - tbd
    38F0E2 - tbd
    38F0E3 - tbd
    38F0E4 - tbd
    38F0E5 - tbd
    38F0E6 - tbd
    39F0E3 - tbd
    39F0E4 - FSG: Quantity Control Valve ( High side) error
    3AF0E4 - tbd
    3BF0E3 - tbd
    3BF0E4 - FSG: Pressure control valve ( High side ) error
    3CF0E4 - tbd
    3DF0E3 - FSG: PCV current too low
    3DF0E4 - FSG: PCV current deviation too high
    3DF0EE - MU_SCM_SPEED_RESET_LEV2
    3DF0FF - MU_SCM_FCUT_RESET_LEV2
    3EF0FF - MU_CPC_32
    3FF0FF - MU_CPC_33
    40F0FF - MU_CPC_34
    41F0FF - MU_EPF_BROKEN_BELT_DETECT
    42F0EE - MU_TSA_BRK_FAIL_ON_BANK1
    42F0FF - MU_TSA_BRK_FAIL_BANK1
    43F0EE - MU_TSA_BRK_FAIL_ON_BANK2
    43F0FF - MU_TSA_BRK_FAIL_BANK2
    441501 - CCV Speed Sensor RPM to Low
    44F0E2 - MU_EGCP_DIA_LBD_FIRED_HIGH
    44F0E7 - MU_EGCP_DIAG_LSL_DYN
    44F0EB - MU_EGCP_DIA_VLS_OFS_LIM
    44F0EE - MU_EGCP_DIA_I_PMP_LIM
    44F0FF - MU_EGCP_DIA_V_PMP_LIM
    450A02 - Turbocharger Compressor Outlet Temp. Sensor, General Temp. Plausibility Error
    450A03 - Turbocharger Compressor Outlet Temperature Circuit Failed High
    450A04 - Turbocharger Compressor Outlet Temperature Circuit Failed Low
    450A14 - Turbocharger Out Temperature, Temperature Too High (Low Box)
    450A15 - Turbocharger Out Temperature, Temperature Too Low (High Box)
    450A1F - MU_RC4_T_COMP_OUT_GEN2
    45F0FF - MU_SCM_SPEED_LIMIT_LEV2
    460002 - J1939 Park Brake Switch Signal from Source #1 is erratic
    460009 - J1939 Park Brake Switch Signal from Source #2 is missing
    46000A - J1939 Park Brake Switch Signal from Source #3 is erratic
    46000D - J1939 Park Brake Switch Signal from Source #1 is missing
    46000E - J1939 Park Brake Switch Signal from Source #3 is missing
    460013 - J1939 Park Brake Switch Signal from Source #2 is erratic
    460A00 - Chage Air Cooler Performance Monitor
    460A02 - Difference Intake Manifold and I Cooler Temperature Out Less Than Threshold (High Box)
    460A03 - The signal voltage of component 10B25: Turbo intake air temperature sensor is too high.
    460A04 - The signal voltage of component 10B25: Turbo intake air temperature sensor is too low.
    460A0B - Charge Air Cooler Outlet Temperature Sensor Plausibility Error
    460A10 - Chage Air Cooler Performance Monitor
    460A14 - Charge Air Outlet Temperature Drift (Low box)
    460A15 - Charge Air Outlet Temperature Drift (High box)
    460A1F - MU_RC4_T_ICOOLER_OUT_GEN2
    46F0FF - FGS: FBS3 data flash defect, exchange ECU
    47050E - Air Compressor Clutch
    470A01 - Low Air Flow
    470A02 - Turbocharger/Supercharger Boost System Performance
    470A03 - The signal voltage of component 10B17: Charge-air pressure/temperature sensor is too high.Measured range: Ladedruck nach Ladeluftkuhler
    470A04 - The signal voltage of component 10B17: Charge-air pressure/temperature sensor is too low.Measured range: Ladedruck nach Ladeluftkuhler
    470A0E - Charge Air Control, Pressure not plausible in brake mode
    470A14 - Intake Manifold Pressure Plausibility (Low Box)
    470A15 - Intake Manifold Pressure Plausibility Error, Pressure Too Low (High Box)
    4B0E03 - Injector Cylinder #1 Spill Control Valve Abnormal Operation (MAX)
    4B0E04 - Component 10Y45 has an electrical fault.
    4B0E06 - Component 10Y45 has a short circuit.
    4B0E0A - 'Injector Cylinder #1 Spill Control Valve (''Amplifier'') Abnormal Rate of Change'
    4C0E03 - Injector Cylinder #2 Spill Control Valve Abnormal Operation (MAX)
    4C0E04 - Component 10Y46 has an electrical fault.
    4C0E06 - Component 10Y46 has a short circuit.
    4C0E0A - 'Injector Cylinder #2 Spill Control Valve (''Amplifier'') Abnormal Rate of Change'
    4D0E03 - Injector Cylinder #3 Spill Control Valve Abnormal Operation (MAX)
    4D0E04 - Component 10Y47 has an electrical fault.
    4D0E06 - Component 10Y47 has a short circuit.
    4D0E0A - 'Injector Cylinder #3 Spill Control Valve (''Amplifier'') Abnormal Rate of Change'
    4E0E03 - Injector Cylinder #4 Spill Control Valve Abnormal Operation (MAX)
    4E0E04 - Component 10Y48 has an electrical fault.
    4E0E06 - Component 10Y48 has a short circuit.
    4E0E0A - 'Injector Cylinder #4 Spill Control Valve (''Amplifier'') Abnormal Rate of Change'
    4F0E03 - Injector Cylinder #5 Spill Control Valve Abnormal Operation (MAX)
    4F0E04 - Component 10Y49 has an electrical fault.
    4F0E06 - Component 10Y49 has a short circuit.
    4F0E0A - 'Injector Cylinder #5 Spill Control Valve (''Amplifier'') Abnormal Rate of Change'
    500E03 - Injector Cylinder #6 Spill Control Valve Abnormal Operation (MAX)
    500E04 - Component 10Y50 has an electrical fault.
    500E06 - Component 10Y50 has a short circuit.
    500E0A - 'Injector Cylinder #6 Spill Control Valve (''Amplifier'') Abnormal Rate of Change'
    510E0E - Injector Cylinder #7 Spill Control Valve Abnormal Operation
    540002 - J1939 Wheel-Based Vehicle Speed Signal from Source#1 is erratic
    540003 - Vehicle Speed Sensor Circuit Failed High
    540004 - Vehicle Speed Sensor Circuit Failed Low
    540009 - J1939 Wheel-Based Vehicle Speed Signal from Source#2 is missing
    54000A - J1939 Wheel-Based Vehicle Speed Signal from Source#3 is erratic
    54000B - Vehicle Speed Failure
    54000D - J1939 Wheel-Based Vehicle Speed Signal from Source#1 is missing
    54000E - J1939 Wheel-Based Vehicle Speed Signal from Source#3 is missing
    540013 - J1939 Wheel-Based Vehicle Speed Signal from Source#2 is erratic
    540015 - Vehicle Speed Failure
    54001F - Vehicle Speed Failure
    580403 - MDEG Brake System (Two Stage Brake), Circuit Failed High
    580404 - MDEG Brake System (Two Stage Brake), Circuit Failed Low
    580405 - MDEG Brake System (Two Stage Brake), Circuit Failed Open
    5E0002 - Der Kraftstoffdruck im Kraftstoff-Niederdruckkreislauf ist zu hoch oder zu niedrig.
    5E0003 - The signal voltage of component 10B56 is too high.
    5E0004 - The signal voltage of component 10B56 is too low.
    5E000F - Fuel Filter Service Warning
    5E0010 - Der Kraftstofffilter ist verschmutzt.
    5E0410 - MU_RC4_EGR_DEV_LOW
    5E0412 - MU_RC4_EGR_DEV_HIGH
    600002 - MU_IS4_CAN_LVL_FEUL_TANK_PLAUS
    601000 - Engine Fuel Filter Water Level Sensor Circuit Failed High
    601003 - Water Level Electrical Water Separator SRC Failed High
    601004 - Water Level Electrical Water Separator SRC Failed Low
    601007 - Electrical Water Separator, Mechanical Defect
    601009 - Engine Fuel Filter Water Level Sensor Circuit Failed High
    60100E - Electrical Water Separator, Valve defect
    60100F - MU_AM_EWS_SERVICE
    601010 - MU_AM_EWS_LIFE_TIME
    610000 - Water in Fuel Lifetime exceeded
    610003 - The signal voltage of component 10B55 is too high.
    610004 - The signal voltage of component 10B55 is too low.
    61000E - MU_ISP_WATER_IN_FUEL_IGNORED
    61000F - Water in fuel
    610010 - MU_ISP_WATER_IN_FUEL_IGNRD
    61001F - Water in Fuel Sensor - Defect
    61020C - Microcontroller Trap has been activated
    611002 - Coolant Inlet Temperature Not Plausible
    611003 - The signal voltage of component 10B52 is too high.
    611004 - The signal voltage of component 10B52 is too low.
    61100A - Coolant Temperature Sensors not Plausible
    611015 - MU_RC4_T_COOLANT_IN_GEN2
    61101F - Engine Coolant Sensor (IN), General Temp. Plausibility Error
    620000 - The signal voltage of component 10B06: Engine oil pan oil level sensor is too high.
    620001 - The signal voltage of component 10B06: Engine oil pan oil level sensor is too low.
    620002 - MU_ISP_L_OIL_UNPLAUS
    620004 - MU_ISP_L_OIL_DEF
    620005 - tbd
    62000D - Oil Level Mesaurement, Configuration Error
    62000E - Der Olstand ist zu hoch oder zu niedrig.
    620010 - MU_ISP_L_OIL_LEVEL_HI_ERR
    620012 - MU_ISP_L_OIL_LEVEL_LOW_ERR
    620103 - Relative Humidity Circuit Failed High
    620104 - Relative Humidity Circuit Failed Low
    630A00 - EGR Flow Target Error Diagnostic - High Flow
    630A01 - EGR Flow Target Error Diagnostic - Low Flow
    630A0A - MU_AM_EGR_SLOW_RESPONSE
    630A10 - EGR Flow Target Error Diagnostic - High Flow
    630A12 - EGR Flow Target Error Diagnostic - Low Flow
    640001 - The oil pressure in the engine is too low.
    640002 - Oil Pressure Plausibility - Engine Running
    640003 - The signal voltage of component 10B07: Engine oil pressure sensor is too high.
    640004 - The signal voltage of component 10B07: Engine oil pressure sensor is too low.
    640005 - Oil Pressure Sensor Stuck High - low speed
    64000A - MU_EPF_P_ENG_OIL_BUILDUP
    640011 - Oil Pressure Low - Engine Start
    640014 - Oil Pressure Plausibility - Stop
    640600 - Charge Air Cooler Low Efficiency
    640602 - Difference Intake Manifold and I Cooler Temperature Out Less Than Threshold (Low Box)
    640603 - The signal voltage of component 10B12: Charge-air temperature sensor is too high.
    640604 - The signal voltage of component 10B12: Charge-air temperature sensor is too low.
    64060B - Intake Manifold Temperature Plausibility Error
    64060E - Difference Intake Manifold Temperature and EGR Temp. Less Than Threshold (Low Box)
    640614 - Intake Manifold Temperature Drift (Low Box)
    640615 - Intake Manifold Temperature Drift (High Box)
    660010 - Intake Manifold Pressure to High
    660012 - Intake Manifold Pressure to Low
    670000 - Die Drehzahl des Abgasturboladers ist zu hoch.
    670001 - Die Drehzahl des Abgasturboladers ist zu niedrig.
    670002 - The value of component 10B34: Turbocharger rpm sensor is implausible.
    670003 - Turbo Charger Speed Sensor Circuit Failed High
    670004 - Turbo Charger Speed Sensor Circuit Failed Low
    670202 - Water Pump Limp Home Mode
    670207 - Water Pump Mechanical Defect Detected
    670213 - Smart Actuator Indicates Actuator Position Error
    670403 - Component 10B34: Turbocharger rpm sensor has a short circuit to positive or an open circuit.
    670404 - Component 10B34: Turbocharger rpm sensor has a short circuit to ground.
    67040A - MU_RC4_BST_SLOW_RESPONSE
    670602 - MU_FAN_FAN_SPEED_FAULT
    690002 - MU_RC4_T_INTAKE_GEN2
    690010 - Charge Air Cooler Efficency
    6C0002 - Ambient Pressure Plausibility Fault (Low Box)
    6C0003 - Control unit 10A20 is defective.The air pressure sensor has a malfunction.
    6C0004 - Control unit 10A20 is defective.The air pressure sensor has a malfunction.
    6C0014 - Ambient Pressure Plausibility Fault (High Box)
    6C0303 - Air Compressor Clutch, Circuit Failed High
    6C0304 - Air Compressor Clutch, Circuit Failed Low
    6C0305 - Air Compressor Clutch, Circuit Failed Open
    6E0000 - The coolant temperature of the engine is too high.
    6E0002 - Coolant Outlet Temperature Not Plausible
    6E0003 - The signal voltage of component 10B51 is too high.
    6E0004 - The signal voltage of component 10B51 is too low.
    6E000E - Die Kuhlmitteltemperatur ist im Vergleich zur Oltemperatur unplausibel.
    6E0012 - MU_RC4_COOL_SYS_FAIL
    6E0014 - Engine Coolant Sensor (OUT), General Temp. Plausibility Error
    6E0015 - MU_RC4_T_COOLANT_OUT_GEN2
    6E001F - Coolant Temperature Differential High
    6F0001 - Coolant Level Very Low
    6F0003 - Coolant Level Circuit Failed High
    6F0004 - Coolant Level Circuit Failed Low
    6F0012 - Coolant Level Low
    6F0013 - Coolant Level Low (CAN)
    710202 - Die Daten auf dem Motor-CAN-Bus sind unplausibel.
    710203 - Die CAN-Leitung high des Motor-CAN-Busses ist defekt.
    710204 - Die CAN-Leitung low des Motor-CAN-Busses ist defekt.
    710208 - MCM UDS DM1 Message Not Received or has Stopped Arriving
    710209 - Control unit 17A03 is not transmitting data on the CAN bus.
    71020E - ACM UDS DM1 Message Not Received or has Stopped Arriving
    710211 - FSG: CAN Communication, ACM no com stage 2
    710212 - FSG: CAN Communication, ACM no com stage 3
    74020D - MCM Powerdown Error
    760202 - Calibration Data Not Plausible
    76020C - Fehler beim Auslesen oder Schreiben des EEPROM.
    76020D - Calibration Data Not Plausible (CPLD)
    760E0D - tbd
    7B0612 - Thermostat Error Detected
    7C0201 - The signal voltage of component 10B31: Crankshaft sensor is too low.
    7C0202 - Die Zuordnung der Signale von Kurbelwelle und Nockenwelle ist fehlerhaft.
    7C0203 - Component 10B31: Crankshaft sensor has an open circuit.
    7C0204 - Component 10B31: Crankshaft sensor has a short circuit to ground.
    7C0208 - The signal from component 10B31: Crankshaft sensor is implausible.
    7C020A - Crankshaft Position Sensor Signal Erratic
    7C020B - Crankshaft Position Sensor Failure
    7C020E - Crankshaft Position Sensor Pins Swapped
    7F020E - J1939 Data Link Failure
    810203 - Component Y619a y1 (Magnetventil 1 VTG-Lader) has a short circuit to positive.
    810204 - Component Y619a y1 (Magnetventil 1 VTG-Lader) has a short circuit to ground.
    810205 - Component Y619a y1 (Magnetventil 1 VTG-Lader) has an open circuit.
    821003 - Compressor Differential Pressure Inlet Failed High
    821004 - Compressor Differential Pressure Inlet Failed Low
    821005 - Turbocharger Compressor Inlet Differential Pressure Sampling Range Failure
    82100D - Turbocharger Compressor Inlet Differential Pressure Sensor Out Of Calibration
    82100E - Turbocharger Compressor Inlet Differential Pressure Sensor Out Of Calibration
    821014 - Turbocharger Compressor Inlet Differential Pressure Too High (Low Box)
    821015 - Turbocharger Compressor Inlet Differential Pressure Too Low (High Box)
    831001 - CCV Speed Sensor RPM to Low
    831003 - Electrostatic Oil Separator Circuit Failed High
    831004 - Electrostatic Oil Separator Circuit Failed Low
    831005 - Electrostatic Oil Separator Circuit Failed Open
    831007 - Oil Separator, Max. Duration Time Reached
    83100E - Oil Separator Circuit Failed Low
    840001 - Air Mass Flow Too Low
    840002 - Air Mass Calibration Exceeded Range Limit
    840007 - Intake Air Throttle Valve Closure Detection- Positive Torque
    84000D - Air Mass Auto Calibration Failed
    84000E - Intake Air Throttle Valve Closure Detection -Braking Condition
    840E1F - MU_DPF_HIR_TM_MODE_ERR
    850510 - MU_OFD_CYL1_INJ_BOI_FAIL
    85051F - MU_OFD_CYL1_OFF_PULL_FAIL
    860510 - MU_OFD_CYL2_INJ_BOI_FAIL
    86051F - MU_OFD_CYL2_OFF_PULL_FAIL
    870203 - Component 15Y32: Engine cooling system viscous clutch solenoid valve has a short circuit to positive.
    870204 - Component 15Y32: Engine cooling system viscous clutch solenoid valve has a short circuit to ground.
    870205 - Component 15Y32: Engine cooling system viscous clutch solenoid valve has an open circuit.
    870510 - MU_OFD_CYL3_INJ_BOI_FAIL
    87051F - MU_OFD_CYL3_OFF_PULL_FAIL
    870E00 - The soot content of the diesel particulate filter is too high.
    870E0F - DPF Zone 3 Condition
    870E10 - Soot Level High
    870E1F - DPF Zone 2 Condition
    880510 - MU_OFD_CYL4_INJ_BOI_FAIL
    88051F - Injector Cylinder #4 Needle Control Valve Abnormal Rate of Change
    880D02 - Intake Throttle Valve, Spring Response Time Not Plausible
    880D03 - H Bridge 1 Circiut Shorted to Battery
    880D04 - H Bridge 1 Circuit Shorted to Ground
    880D05 - H Bridge 1 Circuit Open Load
    880D07 - Intake Throttle Valve, Stuck
    880D08 - Intake Throttle Valve, Current Deviation Too High
    880D0E - Component 10Y26: Throttle valve has an electrical fault or open circuit.
    880D1F - Intake Air Throttle Control Electrical Fault
    880E0F - DPF Ash Clean Request
    880E10 - DPF Ash Clean Request - Derate
    890510 - MU_OFD_CYL5_INJ_BOI_FAIL
    89051F - Injector Cylinder #5 Needle Control Valve Abnormal Rate of Change
    8A0510 - MU_OFD_CYL6_INJ_BOI_FAIL
    8A051F - Injector Cylinder #6 Needle Control Valve Abnormal Rate of Change
    8B0203 - Injector Cylinder #1 Needle Control Valve Abnormal Operation (MAX)
    8B0204 - Injector Cylinder #1 Needle Control Valve Abnormal Operation (MIN)
    8B0205 - Injector Cylinder 1, Needle Control Valve or Amplifier, Failed Closed
    8B0206 - Component 10Y39 has a short circuit.
    8B0207 - Injector Cylinder 1, Needle Control Valve or Amplifier Control Valve, Failed Open or Leakage
    8B020A - Injector Cylinder #1 Needle Control Valve Abnormal Rate of Change
    8B0210 - Cylinder 1 Fueling Error
    8B0212 - Cylinder 1 Fuel Quantity Too Low
    8B021F - Idle Engine Smoothness Control / Cylinder #1 Value Out of Range
    8C0203 - Injector Cylinder #2 Needle Control Valve Abnormal Operation (MAX)
    8C0204 - Injector Cylinder #2 Needle Control Valve Abnormal Operation (MIN)
    8C0205 - Injector Cylinder 2, Needle Control Valve or Amplifier, Failed Closed
    8C0206 - Component 10Y40 has a short circuit.
    8C0207 - Injector Cylinder 2, Needle Control Valve or Amplifier Control Valve, Failed Open or Leakage
    8C020A - Injector Cylinder #2 Needle Control Valve Abnormal Rate of Change
    8C0210 - Cylinder 2 Fueling Error
    8C0212 - Cylinder 2 Fuel Quantity Too Low
    8C021F - Idle Engine Smoothness Control / Cylinder #2 Value Out of Range
    8D0203 - Injector Cylinder #3 Needle Control Valve Abnormal Operation (MAX)
    8D0204 - Injector Cylinder #3 Needle Control Valve Abnormal Operation (MIN)
    8D0205 - Injector Cylinder 3, Needle Control Valve or Amplifier, Failed Closed
    8D0206 - Component 10Y41 has a short circuit.
    8D0207 - Injector Cylinder 3, Needle Control Valve or Amplifier Control Valve, Failed Open or Leakage
    8D020A - Injector Cylinder #3 Needle Control Valve Abnormal Rate of Change
    8D0210 - Cylinder 3 Fueling Error
    8D0212 - Cylinder 3 Fuel Quantity Too Low
    8D021F - Idle Engine Smoothness Control / Cylinder #3 Value Out of Range
    8E0203 - Injector Cylinder #4 Needle Control Valve Abnormal Operation (MAX)
    8E0204 - Injector Cylinder #4 Needle Control Valve Abnormal Operation (MIN)
    8E0205 - Injector Cylinder 4, Needle Control Valve or Amplifier, Failed Closed
    8E0206 - Component 10Y42 has a short circuit.
    8E0207 - Injector Cylinder 4, Needle Control Valve or Amplifier Control Valve, Failed Open or Leakage
    8E020A - Injector Cylinder #4 Needle Control Valve Abnormal Rate of Change
    8E0210 - Cylinder 4 Fueling Error
    8E0212 - Cylinder 4 Fuel Quantity Too Low
    8E021F - Idle Engine Smoothness Control / Cylinder #4 Value Out of Range
    8E0D03 - Actuator Turbo Compound Bypass Circuit Failed High
    8E0D04 - Actuator Turbo Compound Bypass Circuit Failed Low
    8E0D05 - Actuator Turbo Compound Bypass Circuit Failed Open
    8F0203 - Injector Cylinder #5 Needle Control Valve Abnormal Operation (MAX)
    8F0204 - Injector Cylinder #5 Needle Control Valve Abnormal Operation (MIN)
    8F0205 - Injector Cylinder 5, Needle Control Valve or Amplifier, Failed Closed
    8F0206 - Component 10Y43 has a short circuit.
    8F0207 - Injector Cylinder 5, Needle Control Valve or Amplifier Control Valve, Failed Open or Leakage
    8F020A - Injector Cylinder #5 Needle Control Valve Abnormal Rate of Change
    8F0210 - Cylinder 5 Fueling Error
    8F0212 - Cylinder 5 Fuel Quantity Too Low
    8F021F - Idle Engine Smoothness Control / Cylinder #5 Value Out of Range
    8F0D01 - EDV Failed Self Test
    8F0D03 - Component 10Y24 has a short circuit to positive.
    8F0D04 - Component 10Y24 has a short circuit to ground.
    8F0D05 - Component 10Y24 has an open circuit.
    8F0D0E - Doser Metering and Safety Unit Valve Seals Check
    900203 - Injector Cylinder #6 Needle Control Valve Abnormal Operation (MAX)
    900204 - Injector Cylinder #6 Needle Control Valve Abnormal Operation (MIN)
    900205 - Injector Cylinder 6, Needle Control Valve or Amplifier, Failed Closed
    900206 - Component 10Y44 has a short circuit.
    900207 - Injector Cylinder 6, Needle Control Valve or Amplifier Control Valve, Failed Open or Leakage
    90020A - Injector Cylinder #6 Needle Control Valve Abnormal Rate of Change
    900210 - Cylinder 6 Fueling Error
    900212 - Cylinder 6 Fuel Quantity Too Low
    90021F - Idle Engine Smoothness Control / Cylinder #6 Value Out of Range
    900C02 - NOX Inlet Sensor Plausibility Error
    900C14 - Nox Inlet Sensor Drift High
    900C15 - Nox Inlet Sensor Drift Low
    901200 - EGR Cooler Low Efficiency
    901210 - MU_RC4_EGR_COOL_FAIL
    90121F - EGR Cooler Performance Monitor
    91020A - Injector Cylinder #7 Needle Control Valve Abnormal Rate of Change
    91020E - Injector Cylinder #7 Needle Control Valve Abnormal Operation
    910210 - Cylinder 7 Fueling Error
    910212 - Cylinder 7 Fuel Quantity Too Low
    91021F - Idle Engine Smoothness Control / Cylinder #7 Value Out of Range
    92020A - Injector Cylinder #8 Needle Control Valve Abnormal Rate of Change
    92020E - Injector Cylinder #8 Needle Control Valve Abnormal Operation
    920210 - Cylinder 8 Fueling Error
    920212 - Cylinder 8 Fuel Quantity Too Low
    92021F - Idle Engine Smoothness Control / Cylinder #8 Value Out of Range
    940402 - Coolant Temp/Compressor Inlet Temp Plausibility Error
    940403 - The signal voltage of component 10B53 is too high.
    940404 - The signal voltage of component 10B53 is too low.
    940414 - Turbocharger Compressor Inlet Temp. Sensor, General Temp. Plausibility Error
    94041F - MU_RC4_T_COMP_IN_GEN2
    970C03 - Lambda Sensor Heating: ShortCutTo Battery HighSide Switch
    970C04 - Lambda Sensor Heating: ShortCutTo Ground HighSide Switch
    980402 - Compressor Pressure Plausibility Fault (High Box)
    980403 - Turbocharger Compressor Inlet Pressure Circuit Failed High
    980404 - Turbocharger Compressor Inlet Pressure Circuit Failed Low
    980405 - Compressor Inlet Pressure Plausibility Fault (Delta)
    980414 - Compressor Inlet Pressure Plausibility Error, Pressure Too High (High Box)
    980D00 - Fuel Compensation Pressure High
    980D01 - Der Kraftstoffdruck am Bauteil 10Y24 ist nicht ausreichend oder zu hoch.
    980D02 - Doser Fuel Line Pressure Low
    980D03 - The signal voltage of component 10B56 is too high.
    980D04 - The signal voltage of component 10B56 is too low.
    980D0E - The signal of component 10B56 is implausible in comparison to the signal of component 10B57.
    980D10 - Fuel Pressure Too High/Too Low
    980D1F - Fuel Cut Off Valve Pressure Not Plausible
    990B03 - FSG: PCV current deviation too high
    990B04 - FSG: PCV current too low
    9A0D03 - Component 10Y25 has a short circuit to positive.
    9A0D04 - Component 10Y25 has a short circuit to ground.
    9A0D05 - Component 10Y25 has an open circuit.
    9A0D07 - FCV Failed Self Test
    9B0100 - EGR Differential Pressure Failed (High Box)
    9B0101 - EGR Differential Pressure Failed (Low Box)
    9B0102 - EGR Delta Pressure Sensor Out Of Calibration
    9B0103 - The signal voltage of component 10B28: Exhaust gas recirculation pressure differential sensor is too high.
    9B0104 - The signal voltage of component 10B28: Exhaust gas recirculation pressure differential sensor is too low.
    9B0105 - EGR Sampling Range Failed
    9B010D - EGR Delta Pressure Sensor Out Of Calibration
    9B0115 - MU_RC1_DP_EGR_PLAUS
    9C0100 - EGR Temperature Very High
    9C0102 - EGR Temperature Sensor, General Temp. Plausibility Error
    9C0103 - EGR Temperature Sensor Circuit Failed High
    9C0104 - EGR Temperature Sensor Circuit Failed Low
    9C0107 - EGR Cooler Performance Monitor
    9C0110 - EGR Temperature Sensor / Temperature Too High
    9C0114 - EGR Temperature Drift (High Box)
    9C0115 - EGR Temperature Drift (Low Box)
    9C0403 - tbd
    9C0404 - MU_IS4_TURB_IN_SRL
    9D0001 - Der Soll-Raildruck wird uberschritten.
    9D0002 - Die Signalleitung des Bauteils 10B54 hat einen Wackelkontakt.
    9D0003 - Pressure Control Valve High Side Error
    9D0004 - Pressure Control Valve High Side Error
    9D000A - Leakage in High Pressure Fuel System Too High
    9D0010 - Fuel Rail Pressure Low
    9D0012 - Fuel Rail Pressure High
    9E0002 - The status at circuit 15 at control unit MCM02 is implausible.
    A11003 - Injector Needle Control Valve Bank 3, Shorted to Battery
    A11004 - Injector Needle Control Valve Bank 3, Shorted to Ground
    A21003 - Die gemeinsame elelktrische Leitung der Magnetventile fur Druckubersetzer im Kraftstoffinjektor (Zylinder 1,2,3) hat Kurzschluss nach Plus.
    A21004 - Die gemeinsame elelktrische Leitung der Magnetventile fur Druckubersetzer im Kraftstoffinjektor (Zylinder 1,2,3) hat Kurzschluss nach Masse.
    A40000 - Component Y634 (Mengenregelventil Rail) has a short circuit to ground.
    A40001 - Component Y634 (Mengenregelventil Rail) has a short circuit to positive.
    A40002 - Signal '10B54' is implausible.
    A40003 - The signal voltage of component 10B54 is too high.
    A40004 - The signal voltage of component 10B54 is too low.
    A40005 - The voltage supply for component 10B54 is not OK.
    A40007 - High Pressure Pump, Leakage or TDC Position Wrong
    A40407 - Component 10Y38: Turbobrake solenoid valve reports a fault.
    A40408 - Component 10Y38: Turbobrake solenoid valve reports a fault.
    A40409 - Component 10Y38: Turbobrake solenoid valve reports a fault.
    A4040B - Component 10Y38: Turbobrake solenoid valve reports a fault.
    A4040E - Component 10Y38: Turbobrake solenoid valve reports a fault.
    A4040F - Component 10Y38: Turbobrake solenoid valve reports a fault.
    A40410 - Smart Remote Actuator 1 (Wastegate), Temperature Fault
    A40413 - Smart Actuator Indicates Turbocharger Wastegate Position Error
    A40014 - Rail Pressure Sensor, Signal Drift High
    A40015 - Rail Pressure Sensor, Signal Drift
    A4041F - Smart Remote Actuator 1 (Wastegate), Unknown Error Code
    A50202 - The signal of circuit 50 is implausible.
    A50203 - The electrical line A of the starter relay has a short circuit to positive.
    A50204 - The electrical line A of the starter relay has a short circuit to ground.
    A50205 - The starter relay has an open circuit.
    A50207 - Das Steuergerat erkennt keine Motordrehzahl, obwohl der Starter angesteuert wird.
    A5020E - Starter Electronic Fault / MCM Internal Failure
    A50210 - Starter Electronic Fault / ECU internal (Res)
    A50212 - Engine Starter Relay Jammed
    A5021F - Starter does not engage.
    A70207 - Das Druckbegrenzungsventil in der Rail kann nicht schlie?en.
    A80000 - The battery voltage is too high.
    A80001 - The battery voltage in component MCM02 is too low.
    AA0C00 - MU_EPF_T_EXH_HIGH
    AA0C02 - The signal from component 17B04: Temperature sensor, exhaust gas upstream of SCR catalytic converter is implausible.
    AA0C03 - The signal voltage of component 17B04: Temperature sensor, exhaust gas upstream of SCR catalytic converter is too high.
    AA0C04 - The signal voltage of component 17B04: Temperature sensor, exhaust gas upstream of SCR catalytic converter is too low.
    AA0C08 - DOC Inlet Temperature, Signal Spike
    AA0C0A - DOC Inlet Temperature Sensor Stuck
    AB0002 - MU_RC4_T_AMBIENT_AIR_GEN
    AB0003 - Ambient Temperature Circuit Failed High
    AB0004 - Ambient Temperature Circuit Failed Low
    AB001F - MU_RC4_T_AMBIENT_AIR_GEN2
    AC0B03 - EGR Water Cooling Regulator Circuit Failed High
    AC0B04 - EGR Water Cooling Regulator Circuit Failed Low
    AC0B05 - EGR Water Cooling Regulator Circuit Failed Open
    AE0000 - Fuel temperature is too high.
    AE0002 - Fuel Temperature Sensor, General Temp. Plausibility
    AE0003 - The signal voltage of component 10B13: Fuel temperature sensor is too high.
    AE0004 - The signal voltage of component 10B13: Fuel temperature sensor is too low.
    AE0014 - MU_RC4_T_FUEL_GEN2
    AE001F - Die Kraftstofftemperatur ist unplausibel.
    AE0C00 - Der vom Steuergerat berechnete Grenzwert fur die Temperatur am Bauteil 17B13: Exhaust temperature sensor downstream of diesel particulate filter (DPF) wurde uberschritten.
    AE0C02 - DPF Outlet Sensor, General Temp. Plausibility
    AE0C03 - DPF Oulet Temperature Circuit Failed High
    AE0C04 - DPF Oulet Temperature Circuit Failed Low
    AE0C0A - DPF Outlet Temperature Sensor Stuck
    AE0C0E - Abnormal DPF Temperature Rise
    AE0C1F - Abnormal DPF Temperature Rise
    AF0000 - Die Motoroltemperatur ist zu hoch.
    AF0002 - Engine Oil Temperature Sensor, General Temp. Plausibility
    AF0003 - The signal voltage of component 10B11: Oil temperature sensor is too high.
    AF0004 - The signal voltage of component 10B11: Oil temperature sensor is too low.
    AF000E - Component 10B11: Oil temperature sensor has a plausibility error.
    AF000F - Oil Temperature High Pre-Warning
    AF001F - MU_RC4_T_ENG_OIL_GEN2
    B20C00 - The upper limit value for the temperature at the sensor of component 17B03: Temperature sensor, exhaust gas downstream of SCR catalytic converter has been exceeded.
    B20C02 - Component 17B10: Exhaust temperature sensor downstream of diesel oxidation catalytic converter has a plausibility error.
    B20C03 - The signal voltage of component 17B03: Temperature sensor, exhaust gas downstream of SCR catalytic converter is too high.
    B20C04 - The signal voltage of component 17B03: Temperature sensor, exhaust gas downstream of SCR catalytic converter is too low.
    B20C08 - DOC Outlet Temperature, Signal Spike
    B20C0A - Die Temperatur des Bauteils 17B03: Temperature sensor, exhaust gas downstream of SCR catalytic converter verandert sich schneller als physikalisch moglich ist.
    B20C0E - Abnormal DOC Temperature Rise
    B20C1F - Abnormal DOC Temperature Rise
    B30C09 -Abnormal Soot Rate
    B30C10 - DPF Pressure - Out of Range High
    B50D03 - Die Spannungsversorgung (5V) fur die Sensorgruppe 1 ist zu hoch.
    B50D04 - Die Spannungsversorgung (5V) fur die Sensorgruppe 1 ist zu niedrig.
    B60D03 - Die Spannungsversorgung (5V) fur die Sensorgruppe 2 ist zu hoch.
    B60D04 - Die Spannungsversorgung (5V) fur die Sensorgruppe 2 ist zu niedrig.
    B70D03 - Die Spannungsversorgung (3V) fur die Sensorgruppe 1 ist zu hoch.
    B70D04 - Die Spannungsversorgung (3V) fur die Sensorgruppe 1 ist zu niedrig.
    B80D03 - Die Spannungsversorgung (3V) fur die Sensorgruppe 2 ist zu hoch.
    B80D04 - Die Spannungsversorgung (3V) fur die Sensorgruppe 2 ist zu niedrig.
    BA0203 - Gridheater Circuit Failed High
    BA0204 - Gridheater Circuit Failed Low
    BA0205 - Gridheater Circuit Failed Open
    BC001F - Idle Speed Out of range
    BD0403 - MIL Lamp Circuit Failed High
    BD0404 - MIL Lamp Circuit Failed Low
    BD0405 - MIL Lamp Circuit Failed Open
    BE0000 - The engine speed is too high.
    BE0002 - Engine Speed High
    BE0010 - MU_EPF_ENGINE_OVERSPEED
    BF000D - J1939 Transmission Output Shaft Speed Signal is missing
    BF0013 - J1939 Transmission Output Shaft Speed Signal is erratic
    C01407 - MU_RC4_P_INT_LOW_CEL
    C10203 - Digital Output 1 13 Circuit Failed High
    C10204 - Digital Output 1 13 Circuit Failed Low
    C60203 - Digital Output 4 06 Circuit Failed High
    C60204 - Digital Output 4 06 Circuit Failed Low
    C91203 - Catalyst Temperature Sensor Circuit Low Input (Bank 1 Sensor 1)
    C91204 - Catalyst Temperature Sensor Circuit High Input (Bank 1 Sensor 1)
    CA1203 - Catalyst Temperature Sensor Circuit Low (Bank 1 Sensor 2)
    CA1204 - Catalyst Temperature Sensor Circuit High (Bank 1 Sensor 2)
    CB0203 - High Side Digital Output # 1 Circuit Failed High
    CB0204 - High Side Digital Output # 1 Circuit Failed Low
    CC0204 - High Side Digital Output # 2 Circuit Failed Low
    CC0205 - High Side Digital Output # 2 Circuit Failed Open
    CF0409 - ACM Message Not Received or has Stopped Arriving
    D1030E - FAN Clutch Issue
    D30201 - Camshaft Position Sensor Signal Voltage Too Low
    D30203 - Camshaft Position Sensor Open Circuit
    D30204 - Camshaft Position Sensor Short to Ground
    D30208 - The signal from component 10B32: Camshaft sensor is implausible.
    D3020A - Camshaft Position Sensor Signal Erratic
    D3020B - Camkshaft Position Sensor Failure
    D3020E - Das Bauteil 10B32: Camshaft sensor ist verpolt.
    D40203 - Lambda Sensor Heating: ShortCutTo Battery LowSide Switch
    D40204 - Lambda Sensor Heating: ShortCutTo GND LowSide Switch
    D40205 - Open Load of Lambda Sensor Heating - D40206 - Lambda Sensor Heating: Over LoadLoad between High Side and Low Side Switch
    D90200 - Das Bauteil 10A14: Intake air heater flange control unit ist standig eingeschaltet
    D90202 - MU_IS4_SPOR_DEF_1
    D90203 - Component 10A14: Intake air heater flange control unit has a short circuit to positive or an open circuit.
    D90204 - Component 10A14: Intake air heater flange control unit has a short circuit to ground.
    D90207 - Component 10A14: Intake air heater flange control unit is defective.
    D90208 - MU_IS4_SPOR_DEF_2
    D9020E - Grid Heater Special Instructions
    E40D00 - Regeneration of diesel particulate filter
    E40D01 - Regeneration of diesel particulate filter
    E70A02 - EGR Valve Position Incorrect
    E70A03 - EGR Valve Circuit Failed High
    E70A04 - EGR Valve Circuit Failed Low
    E70A05 - EGR Valve Circuit Failed Open
    E70A07 - Component 10Y26: Throttle valve reports a fault.
    E70A08 - EGR Valve Actuator, Internal Test Running
    E70A09 - Component 10Y26: Throttle valve reports a fault.Internal fault
    E70A0A - EGR Actuator Slow Response
    E70A0B - EGR Valve Actuator, Restricted Operability
    E70A0E - Component 10Y26: Throttle valve reports a fault.
    E70A0F - EGR Valve Actuator, Temperature Warning
    E70A10 - Component 10Y26: Throttle valve reports a fault.Excess temperature
    E70A1F - EGR Valve Actuator, Unknown Error Code
    EB0A00 - VNT Valve Position Feedback, Position Too Low (High Box)
    EB0A01 - VNT Valve Position Feedback, Position Too High (Low Box)
    EB0A02 - VNT Valve Position Feedback Failed
    EB0A03 - Position Waste Gate (VNT) Failed High
    EB0A04 - Position Waste Gate (VNT) Failed Low
    EB0A09 - CAN3 Communication Error
    EB0A13 - Smart Actuator Indicates Turbocharger Vane Position Error
    EB0D00 - Inlet Manifold Pressure Failed High
    EB0D01 - Inlet Manifold Pressure Failed Low
    EB0D03 - Intake Manifold Pressure Circuit Failed High
    EB0D04 - Intake Manifold Pressure Circuit Failed Low
    EB0D05 - Inlet Manifold Pressure Sampling Range Failed
    EB0D12 - Inlet Manifold Pressure Failed Low
    EB0D14 - The signal of component Atmospheric pressure is implausible in comparison to the signal of component 10B17: Charge-air pressure/temperature sensor
    EB0D15 - Der vom Steuergerat berechnete Sollwert fur den Ladedruck wird nicht erreicht.
    EC0B0E - Misfire Detected
    ED0A03 - Die gemeinsame elelktrische Leitung der Magnetventile fur Dusennadel im Kraftstoffinjektor (Zylinder 1,2,3) hat Kurzschluss nach Plus.
    ED0A04 - Die gemeinsame elelktrische Leitung der Magnetventile fur Dusennadel im Kraftstoffinjektor (Zylinder 1,2,3) hat Kurzschluss nach Masse.
    ED0F00 - Doser Fuel Line Pressure High
    ED0F03 - The signal voltage of component 10B56 is too high.
    ED0F04 - The signal voltage of component 10B56 is too low.
    ED0F0E - Ein Kraftstoffleck am Ausgang des Bauteils 10Y24 wurde erkannt.
    ED1410 - Fuel Quantity High Detected
    ED1412 - Fuel Quantity Low Detected
    EE0A03 - Die gemeinsame elektrische Leitung der Magnetventile fur Dusennadel im Kraftstoffinjektor (Zylinder 4,5,6) hat Kurzschluss nach Plus.
    EE0A04 - Die gemeinsame elektrische Leitung der Magnetventile fur Dusennadel im Kraftstoffinjektor (Zylinder 4,5,6) hat Kurzschluss nach Masse.
    EE1410 - Cylinder 1 Fueling Error
    EE1412 - MU_ESC_CYL1_SRL
    EF1410 - Cylinder 2 Fueling Error
    EF1412 - MU_ESC_CYL2_SRL
    F00B04 - MU_EGCP_DIA_TTIP_OOR
    F00B14 - MU_RC4_LAMBDA_DEV_HIGH
    F00B15 - MU_RC4_LAMBDA_DEV_LOW
    F01410 - Cylinder 3 Fueling Error
    F01412 - MU_ESC_CYL3_SRL
    F11410 - Cylinder 4 Fueling Error
    F11412 - MU_ESC_CYL4_SRL
    F20B07 - EGR Feedback Control Out of Adjustment High
    F20B0A - MU_RC4_EGR_SLOW_RESPONSE
    F20B0D - EGR System Parametrization Failure
    F20B1F - EGR Feedback Control Out of Adjustment Low
    F21410 - Cylinder 5 Fueling Error
    F21412 - MU_ESC_CYL5_SRL
    F31410 - Cylinder 6 Fueling Error
    F31412 - MU_ESC_CYL6_SRL
    F41410 - Cylinder 7 Fueling Error
    F41412 - MU_ESC_CYL7_SRL
    F51410 - Cylinder 8 Fueling Error
    F51412 - MU_ESC_CYL8_SRL
    F80B0D - DPF System Parametrization Failure
  2. The Following 2 Users Say Thank You to EnCoders For This Useful Post:
    AlGontsov (18th March, 2021), ProTuner (18th March, 2021)
