Results 1 to 9 of 9
    Default How to read ECUs SAK-C167
    Hello friends, I have two ECUs with processor infineon SAK-C167, in the same PCB have 29F400 (maps) and eprom (immo), I consult xprog, vvdi prog, ktag, kess, upa, wellon and I don´t find how read this processor SAK-C167, somebody can read? help me? Thanks very much.
    Jun 2013
    EU
    That processor accepts bootmode. Present in many ECD15 and ME7 ecus for example. Anyway it has only 32Kb internal memory, normaly relies on external flash. With bootmode you can read all memories, internal, external and serial eeprom.
    Right, what´s the software/hardware I can use to read this 32kb internal memory?
    Jun 2013
    EU
    Quote Originally Posted by lolpa View Post
    KKL cable and nefmoto software, or minimon,...
    Dec 2017
    also ktag can read it chiploader post photo pcb or ecu information for help
    bobolin4o's Avatar
    Bulgaria, V. Tarnovo
    Just curious... why is needed to read the processor?
  7. The Following User Says Thank You to bobolin4o For This Useful Post:
    morgano (26th March, 2021)
    Jun 2013
    EU
    Quote Originally Posted by bobolin4o View Post
    For fun or for disassembly of the code purpose.
  9. The Following User Says Thank You to morgano For This Useful Post:
    rafal (26th March, 2021)
  10. #8
    Have VIN and others informations programmed in the processor, I need change.
  11. #9
    Jun 2013
    EU
    Don’t think you are gonna change anything on that processor’s irom, guess is factory programmed and otp. Also doubt VIN gonna be stored there, most likely all that data is in serial eeprom.
  12. The Following 2 Users Say Thank You to morgano For This Useful Post:
    esse (29th March, 2021), lolpa (30th March, 2021)
