Results 1 to 3 of 3
    Aug 2018
    Default 2012 Audi A6 - BCM Location??????
    Hello All,
    Doing all keys lost on 2012 Audi A6 and thought I'd locate the BCM2 in the trunk right hand side behind access panel like I normally do with A4 and Q5. To my surprise - NO access panel . I didn't want to rip everything off to find out it's not there, looked online, not seeing any information. I did run across a diagram that appears to show it behind the back seat, but not sure. Have any of you guys located the BCM2 for this vehicle?? Help appreciated, Thanks.
    Apr 2016
    above rear right wheel arch
  3. The Following User Says Thank You to K1nd3r For This Useful Post:
    ammreid (28th March, 2021)
    Aug 2018
    Quote Originally Posted by K1nd3r View Post
    Thanks sir, spend a lot of time yesterday looking and couldn't find anywhere - then came across a tread on Audi Forum where guy was trying to add a remote start or something and had to access the BCM... I notice, the entire right trunk liner has to be removed along with backseat to make it easier to pull it away - what a pain.
