Results 1 to 9 of 9
    Oct 2015
    Default fvdi 2014 problems
    hi all.
    my fvdi 2014 with serial F04551 stoped work properly. in this moment vw 8.6 aplication can be loaded only. reinstalated software much times. sometimes work all 3 version vw, sometimes after reinstalation work another one or two car other no.sometimes got error 5. tried several usb and cusb port seting without success.my window is xp. any halp?
    some examples:
    6841707059 576F526B 57416E5453 596F55 526F6B69424152
    Mar 2018
    UK
    Take old laptop - format the hard disk - Install XP 32 and dont install other programs use it only for FVDI
  3. The Following User Says Thank You to Manta1600 For This Useful Post:
    rokibar (3rd April, 2021)
    May 2020
    Make a new partition on your drive and install a 32bit windows on it. Install fvdi on it and use that partition only for FVDI. I had a same problem when I had vcds installed on same windows with fvdi. It causes instability for some reason. Leave the other partition for your old windows with your old softwares.
    EDIT: One small thing to add, make sure you disable selective usb suspending in power managment setting on your windows, it also causes simmilar errors to devices connected after booting into OS.
    Last edited by turismou; 3rd April, 2021 at 07:22 PM. Reason: A few additional notes
  5. The Following User Says Thank You to turismou For This Useful Post:
  6. #4
    Oct 2015
    Thanks guys. Will try that.
    Oct 2015
    Guys, make new particon at D installed xp and installed fvdi. Work great until open first window. Software go on. Than I installing again and working. What to do now?
  8. #6
    May 2020
    Quote Originally Posted by rokibar View Post
    If all work well, leave it as it is. Just disable USB suspending in power options (just in case) cause it could cause problems sometimes.
  9. The Following User Says Thank You to turismou For This Useful Post:
    rokibar (5th April, 2021)
  10. #7
    Oct 2015
    Will try it.
  11. #8
    Oct 2015
    No goes. After some times if i want use tham i have instal again. Same with smok uhds alinone. My laptop is fresh reinstalled and without antivirus.
  12. #9
    Oct 2015
    Solved with new laptop.
    Thanks all
