Hi need some help Dodge Journey 2.0 CRD 6DCT450 (Getrag) SXT 2009 FWD
Have problems with Turbo no Boost.
No OBD2 Fault codes
Launch at Live Data show ''Red data'' on All Boost Values, on all 3 sensors ~1000 KPa at 0-660 KPa aloved (Also on not working engine)
Also Current terminal 15 Voltage are Wrong ~120 V Without working engine ~140 Volts At Working engine
Battery voltage is ok 12 and 14 Volts
No information about previous Flashing ECU (Seams DPF OFF and RGR OFF) My Feeling there is some thing wrong Wits Flash or ECU it self.
I read Flash by KessV2
Is there anyone here who can compare Flash?
No stage required-Just stock without DPF and EGR ( Swirl flaps seams work, must be checked in flash)
Or maybe there is some problem with ECU -Suggestions are welcome. Also ECU pinot P05094821AE GHY41 to Check some values with multimeter
My files can be downloaded ->
https://drive.google.com/file/d/1DKC...ew?usp=sharing
