Results 1 to 7 of 7
    drugowaz's Avatar
    Mar 2015
    Lithuania
    Default Golf 5 1.9 pd strange stahl problem when driving
    minute ago
    Please advice
    Have golf 5 1.9 77kw pd engine.
    Sympthom car stalhs when driving. And not start untill stay a while. It turns over starter fast,but fees like no fuel it injected.
    Pump in tank replaced.
    No errors in diagnistics. Cranchaft sensor signal is present. No alarm nothing.
    One thing not tradicional maybe its very warm or even hot fuel filter housing.
    Anyone knows something?
    Aug 2018
    Romania
    I would assume hoses incorrectly mounted on the diesel filter or on the tandem pump (maybe even on the electric pump in the tank). which involves reversing the route, so that the mechanical valves that deal with fuel cooling work in vain.
    Or maybe even faulty valves in the diesel filter cover.
    I don't know how it behaves with a return hose, clogged ...
    Do not forget to press Thanks and Reputation buttons!
    Mar 2020
    in the field
    the filters will be warm, the fuel flows through the head for this temperature check the main fuel pump, see if there is a leak in the gearbox
    Feb 2021
    Check high pressure fuel pump for failure
    could also be worn cam shaft and valve lifters
    tepSIJA's Avatar
    Dec 2015
    OTP
    Quote Originally Posted by sebage View Post
    i have SAME problem like you writte here, inlet and outlet swaped , many mechanic try to solve problem but no one check this hoses.
    Tempus Omnia Revelat
    Aug 2018
    Romania
    The principle of operation is a little more complicated than in other cases, that's all ... you just need a little attention.
    chrissysnaith's Avatar
    Apr 2019
    north east uk
    have crank sensor logged ive seen this on my own car took weeks of car dying when warm ,left to cool down would fire up fine then die again when hot
    finally threw code for crank sensor replaced and car ran spot on
