Results 1 to 11 of 11
    Hampshire
    Default Nissan Micra K12 2005 remote problem
    Hi lads
    This nissan micra K12 with twist ignition came for a new spare oem remote key, but the remote stops working once every 7 days or something(the car starts), but her original one is ok, any ideas?
    Mar 2018
    UK
    Did you try to erase all remotes and then program both again?
  3. The Following User Says Thank You to Manta1600 For This Useful Post:
    Krazaki (28th December, 2024)
    p1et's Avatar
    Oct 2013
    The best idea is to run away from this car. I mean, seriously.
    Last time I changed remote shell and day after, car stopped starting (sometimes does, sometimes not) and customer blames ME. I spoke about that with my colleagues and they had simillar issues. Just look for Micra K12 starting problem on google, noone knows the answer WTF is happening with this sh1t. And you know what, you DON'T wanna be 'the last guy' who touched it.
  5. The Following 5 Users Say Thank You to p1et For This Useful Post:
    fred77 (17th May, 2021), Kalectro (11th December, 2022), musti418 (15th October, 2021), super jumbe (19th April, 2021), Weasel3 (20th April, 2021)
  6. #4
    Hampshire
    No mate, these are a bit dodgy, didnt want to knock out the working one, i had these in the past but not this frequent after few days, also noticed that keyless no working on the car!
    super jumbe's Avatar
    Livingstone
    Diabolical working on keys on Nissan cars before adding any keys it tells you all the keys will be erased so after the keys are erased if it fails to programme again you done the system is not good, I would run.
  8. #6
    Hampshire
    I hear you p1et and SJ, i personally dont like doing these i will put a new battery and see what the customers want to do,maybe a new remote.
    ps, can the id60 chip be reused on these?
  9. #7
    Mar 2018
    UK
    Today I had the same car to add new key - the car has only one key that start only emergency with the blade on the ignition
    I spent 1 hour to try to add new key but the car take only the original key and noting else
    I tried 4 used keys from Micra with 4D and one brand new - no success - disconected the battery noting
    There was fault on the BCM about fault CAN comunication and I left the job
  10. #8
    keyprogramming's Avatar
    Quote Originally Posted by Manta1600 View Post
    Had exactly the same just before lockdown.
    Brand new genuine remote would not program in, tried everything
    Then the original stopped working as well, no RCL, no start.
    Left it for an hour while I went and did an overdue job.
    Came back, and the original had miraculously started working again.
    Told the customer I wasn't wasting anymore time, and suggested taking it to Nissan.
    Still got the unused remote somewhere in the van.
    Definitely give these a wide berth.
  11. The Following User Says Thank You to keyprogramming For This Useful Post:
  12. #9
    Hampshire
    I must have been lucky, both remote and keys programmed with ad100, no problem, the starting is ok but new remote, drops off the system, refund was issued, and customer was sent to the main dealer, will do lost keys on these now till i get rid of my 2 new remotes.
  13. The Following User Says Thank You to nazz2 For This Useful Post:
  14. #10
    newone's Avatar
    Oct 2016
    done a note e11 id60 couple days ago with truecode and a original remote to add,everything went ok 3 minutes job,truecode do not list e11 for proximity key but did it under micra
  15. The Following 2 Users Say Thank You to newone For This Useful Post:
    godfathertwo (17th May, 2021), Weasel3 (17th May, 2021)
  16. #11
    May 2020
    I'm trying to help a friend fix a Micra with twist key. Someone before us was doing some work on the ignition lock and I don't know what they exactly did yet.
    Car is not starting atm, the case broke and they lost the tp. I added an Xhorse superchip prepared as 4d60, when I go to programming with SBB it says no loaded key, avdi Nissan says successful but no difference, obdstar says success but 0 new keys and Launch says success but ot shows 2 keys already in memory as if nothing was done...
    What I find weird is that I can turn the twist even though remote is not programmed and not in ignition, when I try with key in ignition, immo light goes off, but no start.
    What di you people think about this? I was thinking to virginise the lock and adapt it again but I'm not sure it'd make a difference.
    Edit: Also, I can't program remote if no programmed tp is available..
