Page 1 of 3 123 LastLast
Results 1 to 15 of 37
    Jun 2018
    Default Renault Scenic 1999-2003 immo
    Hi friends, my name is Moaaz from Germany , i have scenic year 2000. Inside have mcu mc68hc705b32 (3g96A) plcc
    I have read it with Xprog 6.26 Clone
    This car crank but no start , and no immo light in Cluster
    Please can you check the file if there any problem ? and how to reprograming the key ? or how to swap the UCH , or any other idea to start the car
    Thanks for all
    Attachment 804581176385753_150187767036717_2724132012419599912_n.jpgAttachment 804581renault scenic 1999 UCH Original.rar176491069_150187820370045_7971331486685455390_n.jpg176311667_150187787036715_4585501657954902565_n.jpg178653055_152576506797843_5171326216070353826_n.jpg176491069_150187820370045_7971331486685455390_n.jpg176311667_150187787036715_4585501657954902565_n.jpg178653055_152576506797843_5171326216070353826_n.jpg
    PHP Code:
    [PHP
    [/PHP]
    rafal's Avatar
    UK - PL
    need help
    now my goal is to buy xp-005
    who will help?
  3. The Following 2 Users Say Thank You to rafal For This Useful Post:
    brend (26th April, 2021), Louislesinge (26th April, 2021)
    Jun 2018
    thank you , but i donīt have this tool , other solution ?
    can you check if the dump file ok ?
    rafal's Avatar
    UK - PL
    Quote Originally Posted by Essen cars View Post
    if need - buy this
    need help
    who will help?
    Louislesinge's Avatar
    Jun 2017
    French Jungle
    Your problem is not clearly stated. If everything is original and the immobilizer indicator light no longer flashes, check the permanent power supply of the UCH. If ok, your UCH is out of order or has spontaneously become blank (when the UCH is new, the LED does not flash).
    So what is the initial problem? Did you dismantle the UCH because the light stays off or is it off since you read or corrected the dump?
    What is the car's injection ECU?
    Greetings,
  7. The Following User Says Thank You to Louislesinge For This Useful Post:
    rafal (26th April, 2021)
  8. #6
    credoline's Avatar
    Србија
    Yours file in Motorola is damaged. The most time problem with this UCH module is water what they get over the cables. Originaly in car over UCH module is rubber cover.
    I am 2 times success to repair file. Repaired file in attachment, not sure will work.
    Good luck
    [QUOTE=Essen cars;4115750]Hi friends, my name is Moaaz from Germany , i have scenic year 2000. Inside have mcu mc68hc705b32 (3g96A) plcc
    Thanks for all
  9. #7
    Jun 2018
    Quote Originally Posted by Louislesinge View Post
    Greetings,
    thank you , this car came to me from other Work shop , i didn't have full information before , yes i have dismantle the UCH because the light stays off , the Engine
    ECU siemens S110030214 , motor 2.0 Benzine 103 KW , Year 1999 .
    BR
  10. #8
    Jun 2018
    [QUOTE=credoline;4115953]Yours file in Motorola is damaged. The most time problem with this UCH module is water what they get over the cables. Originaly in car over UCH module is rubber cover.
    Good luck
    Thanks for all
    thank you , i will test it
    BR
  11. #9
    Jun 2017
    French Jungle
    Ok,
    So what is required, to start the car or to make remotes and central lock work again?
    If the owner just wants to drive again we can try to help you to remove immo in the Sirius 32 ECU.
  12. #10
    Jun 2018
    Ok,
    ok , that's good too , how to do that ?
  13. #11
    Jun 2017
    French Jungle
    Well, open ECU post some pictures of full mainboard, then we will tell you if you need to read 29F flash and post the dump here.
    Please, remind we all try to help you, so please begin to press our "thanks" in left side...
  14. The Following User Says Thank You to Louislesinge For This Useful Post:
    Essen cars (28th April, 2021)
  15. #12
    Jun 2018
    ok , i will
  16. #13
    Jun 2018
    hi m this photo for Siemens
  17. #14
    Jun 2017
    French Jungle
    Ok,
    There is no CAN chip, so can you read Flash 29F200 (or 29F400) and put the dump here?
  18. #15
    Jun 2018
    yes , but can i read it with UPA , Xprog , or must with others ?
