Results 1 to 4 of 4
    Dec 2009
    Default 2004 SATURN VUE ALL KEYS LOST
    Hello Mate
    Have ALL KEYS LOST Situation on a 2004 SATURN VUE which pictures are attached. Can someone with passed experience with this car help me with reliable immobilizer information that can help me make a Key for this car. Have examine the car and there is No ANTENNA at the key Switch.
    Best Regards
    ray-ray's Avatar
    Nov 2009
    Inside the ignition housing is a resistor that need to be program using a B106 key non transponder. 3X10min. Is the on board process. 10min to the “ON” position then turn it off and back to “ON” for the next 10min then repeat it for the last 10min. Now the car should start.
  3. The Following User Says Thank You to ray-ray For This Useful Post:
    ngakson2002 (1st May, 2021)
    Dec 2009
    Quote Originally Posted by ray-ray View Post
    Thanks a million Friend,
    Please is the B106 key non transponder a special Key.In fact a local Locksmith made a Simple blank Key which can Turn ON and Off the Ignition. Will this key work with the Procedure
    Best Regards
    ray-ray's Avatar
    Nov 2009
    Yes it will work.
