    Jun 2018
    Default BDC/FEM programming with E-SYS without a car / VVDI2 error
    Yesterday I could not make the keys to the BMW F15 with VVDI2. I must say that there was no access to the car, since it was far away and available only the BDC and the ISN with ECU.
    BDC SWFL 00002419_052_010_030
    This version of the SWFL is not supported in the VVDI2 and asks to upgrade the BDC.
    However, I was unable to perform a BDC upgrade using E-SYS on a table without a car, error: error ID:9 - Vehicle not in state Pruefen_Analyse_Diagnose / ignition not activated (clamp 15 off). The test platform has an ignition contact in the dashboard connector, closing the contacts in the dashboard connector did nothing (I don't have a dashboard and access to the car)
    Has anyone done BDC/FEM programming with E-SYS on a table without a car? What I need for programming BDC/FEM with E-SYS on the table? Connecting the dashboard will allow to perform programming?
    And the Xhorse make support for this old version of SWFL, I am silent about the SWFL version after the ISTA 4.28.32 update. VVDI2 weak device for BMW and need to buy more productive equipment
    Jan 2019
    United Kingdom
    Connecting dashboard has nothing to do with flashing fem on bench
    Jun 2018
    And What I need for programming BDC/FEM with E-SYS on the table?
    Feb 2018
    Glasgow area
    Quote Originally Posted by urshul View Post
    A test platform or a good set of test cables and a steady 13.4v.
    I use CGDI BMW on these and it works perfectly on the bench. I've never tried E-sys on the bench.
    Jun 2018
    Quote Originally Posted by PixelsFixed View Post
    Thanks.
    But the question is precisely to produce programming on the bench with E-SYS
    VVDI2 does not have a programming function as opposed to CGDI BMW
    Mar 2018
