Results 1 to 4 of 4
    PSAcars's Avatar
    Oct 2015
    HOME
    Default RNEG myway no satelite found
    Hello to all. This is my c5 x7 satnav with no satelite found. Other part of head unit is ok. So far I put new antenna from citroen --- ( no sat with new antenna ),
    other head unit from working car --- ( with my antenna working fine )
    try to update to v40 from v29 --- ( no sat found ).
    Does any one hade problems like this? Can it be still software problem?
    PSAcars's Avatar
    Oct 2015
    HOME
    Hello to all. Little more info, firs ic in path of gps signal is se4110l, tested connection to main cpu ( bga mount mcu ) I have ordered new se4110 to swap and try again. From working navigation I took signal map and compare to mine.
    hello,
    do you find a solution ?
    l have the same problem
    hello,
    my rneg work again
    disconnect the rneg for 15-20 min
    connect it
    reset , press 1+3+5
    the gps come back but the car in 50 meter shifted the road on the map
    re install the last firmware , already install but re install
    format the sd card with map and re copy map on the sd card
    miracle it work fine
  5. The Following User Says Thank You to eric paris For This Useful Post:
    audiopoint (28th July, 2022)
