Results 1 to 15 of 16
    Sep 2016
    south africa
    Default Writing key into astra h CIM dump
    Can someone pls help me. I want to write a astra h key into the cim dump with with hex editor.I can read the dump. I can read the pin. Having issues programming a key via obd. It is refusing. Original key is lost. I want to manually ad it into the dump. Have zed bull mini, cn900, xhorse vvdi key programmer, opcom, upa programmer and tl866ll. I do not know how and where to ad it manually in hex or software. Please assist and explain to me how to do it please. Also I am using a carbon transponder chip.
    Sent from my SM-A515F using Tapatalk
    Mar 2019
    Earth
    What type of key are you trying to add ? It needs a PCF7941 (DESIGNED FOR ASTRA H NOT CORSA D !!!) ,Works flawless with opcom /fvdi clone .
    also make sure your antenna coil is properly screwed in because either you manage to add key to dump it will fail recognizing the new key .
    Sep 2016
    south africa
    Quote Originally Posted by 12manux View Post
    Received a vvdi key from a friend/locksmith. One of those ones that you can program yourself. He prepared it for me. But its not working. Refuse to program. With Abrites or opcom. In my business I rely heavily on opcom. Heavily and I know it will work. it always does. Bit this CIM is refusing to accept any key. I also deleted all existing keys but still no avail. Am now trying a superchip. Was able to successfully clone another astra h and it worked. Car stars. So now wanna use the same chip. Have already tried but still nothing. That's why I want to manually ad the key into dump. I program keys always but this vehicle is fighting me. Unless I'm making a error when preparing the transponder. Pls assist. Otherwise wanna write into dump. I am not a locksmith. We run a opel specialized workshop so I do all programming,immo off,ecu repairs, pin reading and eeprom/mcu readings myself. If I can successfully program via obd then doing it into hex is not needed. However still want that skill as it is a valuable ad on to my toolkit. Pls assist
    Sep 2016
    south africa
    Using a replacement superchip
    Mar 2019
    Earth
    VVDI or KD or any other key would not work for Astra H . YOU need original or clone oem PCF7941 as i showed you in the picture .This is one of the easiest jobs you can do,with pincode and proper key 2 minute job.Do not waste any more minutes and get a proper key
    Sep 2016
    south africa
    Only problem is I have cloned a key with vvdi and it worked. I did it yesterday on the other astra h and it worked perfect. So I slightly disagree with you here.
    Mar 2019
    Earth
    CLONING ,yes ,i cloned myself BUT you said you want to program to CIM module.There is a HUGE difference in programming a key into imobiliser and sniffing data signal and cloning a chip.
    Mar 2019
    Earth
    A oem clone key with remote is 15$ btw
  9. The Following User Says Thank You to 12manux For This Useful Post:
    mister opel (12th May, 2021)
  10. #9
    kiszka's Avatar
    Please, use the button Edit Post
    do not write, alone Under yourself
    Reality of life :
    1:Never argue with an idiot, he will drag you down to his level and beat you with experience
    2:It’s hard to argue with a genius. It’s impossible to argue with an idiot
    3:Jealousy is a sign of inferiority
    4:Everyone lies
    How much rubbish you leave behind, so much rubbish someone will have to read, or maybe you yourself
    If you like to read garbage, don't slow down, just speed up
  11. #10
    Sep 2016
    south africa
    Ok. I hear you. I am now confused. Very.
  12. #11
    Sep 2016
    south africa
    So I cannot use xhorse vvdi mini key to generate any transponder and code it. Only a complete pre generated 7941 complete keyfob key will work here?
  13. #12
    Mar 2019
    Earth
    YES ,when you want to program a key to imobiliser thekey needs to be oem (because it is precoded for astra h) .If you want to clone it after you can succesfully clone it with KD X2/KEY TOOL and so on ........simple math .........
  14. #13
    Sep 2016
    south africa
    Ok. I got a new key.........and it took first time. Tnx.
  15. #14
    Sep 2016
    south africa
    But you say i can now just clone this key and remote?
  16. #15
    Jun 2013
    Quote Originally Posted by mister opel View Post
    Not remote.
    Only start engine.
