Results 1 to 2 of 2
    Mar 2019
    Polska
    Default wiring diagram abs / esp Peugeot 307
    cześć przyjaciele, mam problem z zasilaniem pompy abs / esp i mogę problemy z komunikacją. potrzebuje schematu okablowania abs / esp i może
    Mar 2019
    Polska
    coped with the power supply, there was no transition in the gray bsm plug pin 3. now there is one error u1208
    and the problem with the assistance, it starts to work only after starting the car because it does not see that the engine is running.
    Edition:
    fixed fault, damaged egr cable.
    there is still a problem with the power steering
    Edit:
    The black plug with 40 wires should send the engine running signal to the power steering pump. the wire is intact and there is no signal from pin 12 of the pe connector.
