    May 2013
    UK
    Default Fiat Punto 1998 1.2 Marelli IAW 59F.M3 Immo off
    Good afternoon,
    May i ask immo off for this car please?
    Fiat Punto 1998
    1.2
    Marelli IAW 59F.M3
    HW303
    1808 OMZ
    I need 100% stable version because i don't have the car just the ecm so i can not test it.
    thank you very much!
    Gammoudi's Avatar
    Dec 2017
    ECUS
    no immo off only virgin
  3. The Following User Says Thank You to Gammoudi For This Useful Post:
    kiskakas (20th May, 2021)
    May 2013
    UK
    Quote Originally Posted by Gammoudi View Post
    if I use virgin then I have to resync the ecm with immo?
    Panathaole's Avatar
    Oct 2017
    HELLAS - E.U.
    It is autocode, but if you use second ecu, you may have to adapt some thinks....
    probably can make off but must cut can L H, then engine light always on, must use timer in can....
    Nov 2017
    Dobruja
    Apr 2016
    will someone turn off the immo?
    iaw59f e4
