Results 1 to 8 of 8
    Mar 2020
    Germany
    Default Fiat Ducato EDC15C7 0281011052 Problem after immo OFF
    Hello
    I have make Immo OFF with UID on EDC15C7 from 2005 Fiat Ducato 2,3l JTD.
    Immo OFF work. Engine start und runs good. I have delete the U1600 code and checksum is also ok.
    Also disconnect immobilizer box under the steering wheel.
    I have make immo OFF in Flash and Virgin eeprom all with UID.
    My Problem is. When i drive after 2000 RPM the MIL goes on and stay on. No Faulty code in ecu.
    What could it be? 5 mounth ago i have make immo off on 0281010486 ecu and become the same poblem.
    Could someone check my files. Maybe i make anytime the same error.
    Another question what happend when i connected immo box back.?
  2. The Following User Says Thank You to wowa557 For This Useful Post:
    Tuomas (1st July, 2021)
  3. #2
    rafal's Avatar
    UK - PL
    write this eeprom..................
    need help
    now my goal is to buy xp-005
    who will help?
    Mar 2020
    Germany
    Thank you Rafal. I would try it. Someone has written that to solved the problem with the engine light the immobox must connected back.
    What do you think. I think the engine would never start !?
    and a known problem on this ecu, when the dtc u1600 is not removed properly
    rafal's Avatar
    UK - PL
    still immobox disconnected.......
    your eeprom virgin not done correct
    need help
    who will help?
  7. The Following User Says Thank You to rafal For This Useful Post:
    wowa557 (24th May, 2021)
  8. #6
    Mar 2020
    Germany
    I have delete U1600 with MTX DTC Remover and in ecu is not DTC after diagnostic.
    Rafal i would try your file. I want just know more about disconnect immobox or better not.
  9. #7
    Mar 2020
    Germany
    The Virgin from UID is not 100% correct. Thank you rafal, i have change line 180 in eeprom.
    Engine light is off. Immo box was disconnected.
  10. #8
    marsete's Avatar
    Oct 2010
    SPAIN
    Quote Originally Posted by rafal View Post
    Rafal is the best,i desesperate in light dashboard peugeot boxer,and solution rafal in eprom is perfect solution.Very thanks rafal
  11. The Following User Says Thank You to marsete For This Useful Post:
    rafal (16th June, 2023)
