Results 1 to 15 of 19
    vialli's Avatar
    Aug 2018
    Romania
    Default Nissan JUKE 2011 hard to find pincode
    I tried to read BCM code with Lonsdor and OBDSTAR X300DP and both failed
    I took a picture with the label on BCM, it is possible to find out the pincode from here ? What is useful from label ?
    super jumbe's Avatar
    Livingstone
    You can programme with 12 digit from glowbox label I have done few with truecode and make shore the car battery is full otherwise you are done......
  3. The Following 2 Users Say Thank You to super jumbe For This Useful Post:
    p1et (8th June, 2021), vialli (9th June, 2021)
    fred77's Avatar
    Jun 2019
    last time i did one truecode was only tool which worked
    Solidarity with Ukraine
  5. The Following User Says Thank You to fred77 For This Useful Post:
  6. #4
    vialli's Avatar
    Aug 2018
    Romania
    Thank you guys for tips, I called the customer today and read the label from glovebox , calculate the pincode with OBDSTAR and tried to programming with Lonsdor
    The pincode was good bcs Lonsdor erased the keys but not programmed at all, new or old, the immo lamp remains ON
    The OBDSTAR it also does not extinguish the lamp
    I don't have Truecode
    vialli's Avatar
    Aug 2018
    Romania
    This is the glovebox label, and the pincode I've used is
    230F142A1A6D
  8. #6
    autochei's Avatar
    Mar 2013
    romania
    zedfull can do
  9. The Following User Says Thank You to autochei For This Useful Post:
  10. #7
    vialli's Avatar
    Aug 2018
    Romania
    Quote Originally Posted by autochei View Post
    zedfull can do
    Yes, you are right Zedfull can do it but also OBDSTAR can do it !!!!!!
    Finally I succeeded to programming 2 keys, the old key and the new one
    2 keys work on Nissan JUKE 2011, blade
  11. The Following 2 Users Say Thank You to vialli For This Useful Post:
    antonypaul (16th June, 2022), super jumbe (10th June, 2021)
  12. #8
    kemaster's Avatar
    BG
    Quote Originally Posted by vialli View Post
    So what was the problem?
  13. #9
    autochei's Avatar
    Mar 2013
    romania
    tool was the problem
  14. #10
    lion0304's Avatar
    Oct 2014
    Juke i've did alway 4 digits
  15. #11
    vialli's Avatar
    Aug 2018
    Romania
    I was successful with 12 digits PINCODE, the green one in the post above
    With this pincode the Lonsdor erased the keys memory and it didn't record anything, probably software bug
    OBDSTAR has too many system options of CAN for 12 digits pincode, 6 or 7 systems I don't remember exactly
    There are differences of steps to foloww depending on the system you choose, if you choose the lucky one YOU WON !!!
    If you want something fun use OBDSTAR for JUKE !!!
  16. The Following User Says Thank You to vialli For This Useful Post:
  17. #12
    p1et's Avatar
    Oct 2013
    So finally, what device worked for you to program both keys, because im a bit lost right now?
  18. #13
    vialli's Avatar
    Aug 2018
    Romania
    Quote Originally Posted by p1et View Post
    Obdstar 300 dp
  19. #14
    Jun 2013
    Or calc with Ostar the right pin. And then test program with IM tool.
  20. #15
    Livingstone
    How many times he need to say OBDSTAR at list we got to know the safer tool to use on Nissan.
  21. The Following 2 Users Say Thank You to super jumbe For This Useful Post:
    antonypaul (16th June, 2022), vialli (10th June, 2021)
