Results 1 to 8 of 8
    Jun 2021
    Default Precoding: Renault learning keys with CLIP…
    Hello
    i have a Renault master 2011, a key with 2 buttons. (PCF7947)
    We bought 2 extra keys from internet, i was reading for programming. I have the Renault Clip and pin code program.
    but do I need to precode my key? (ps: it is a new key from AliExpress)
    Or do I can just program it with clip? (Ps: I want that the 2 buttons on the key work for opening door please)
    thanks in advance
    Dec 2018
    UA
    Try it. Write it down at 7947.
  3. The Following User Says Thank You to Alis1 For This Useful Post:
    JonasR (12th June, 2021)
    Jun 2021
    Hey
    Can I first learn the keys with the clip or must the pre code always happen first?
    I don't have a device to precode, and if I could learn it with the clip first then I could use the key (temporarily) without RF ...
    (I read that on the internet but is it true?)
    and what device you advice me for precode?
    I want to thank you very much for the precode data!
    Thank you in advance
    Dec 2018
    UA
    Write the configuration into the 7947 chip using any programmer, and only then write it into the CLIP machine.
  6. The Following User Says Thank You to Alis1 For This Useful Post:
    Jun 2021
    is this good for programming this?
    https://m.lightinthebox.com/nl/p/min..._p7595012.html
    Thanks in advance
  8. #6
    Dec 2018
    UA
    Yes it will do. Inexpensive budget option.
  9. The Following User Says Thank You to Alis1 For This Useful Post:
  10. #7
    Jun 2021
    Hey
    Sorry but is that precode data correct? I myself looked around on this forum and it my result was that this is the precode for the 3 buttons remote (just to be clear I have a key with 2 buttons).
    Sorry if I'm wrong, better double check!
    Are there people that used already the zedbull mini for this? I receive the zedbull mini normaly monday or tuesday, what program i best can use? On internet i read zed bull have a program for this but i didn't find anywhere a download?
    thanks in advance
  11. #8
    Jun 2021
    Today i received the zedbull mini, i installed the software and drivers and used EFFI (Not so easy to use the software doesn't want to use on a VM, i use VMWARE but it has succeeded).
    But it looks my key was already precoded with settings?
    Is this good?
    A other person says to me that the precode data for a 2 button key needs to be this:
    But please can anybody says what right is?
    Or is this right? (Thanks to: @Alis1)
    I hope anyone can help me.
    Thanks!
