Results 1 to 15 of 15
    Jun 2021
    Default VW 2002y NEW Beetle M5.9.2 immo off
    Pls help everyone.
    I need immo off.
    VW 2002y NEW Beetle immo2 car
    BOSCH M5.9.2
    eeprom 24C02
    06A 906 018 HD
    0 261 207 056
    pontaponta
    Gammoudi's Avatar
    Dec 2017
    ECUS
    kiszka's Avatar
    Quote Originally Posted by pontaponta View Post
    Pls help everyone.
    I need immo off.
    BOSCH M5.9.2
    eeprom 24C02
    06A 906 018 HD
    0 261 207 056
    pontaponta
    eeprom ok
    https://mega.nz/file/l3wCDY6K
    Reality of life :
    1:Never argue with an idiot, he will drag you down to his level and beat you with experience
    2:It’s hard to argue with a genius. It’s impossible to argue with an idiot
    3:Jealousy is a sign of inferiority
    4:Everyone lies
    How much rubbish you leave behind, so much rubbish someone will have to read, or maybe you yourself
    If you like to read garbage, don't slow down, just speed up
  4. The Following User Says Thank You to kiszka For This Useful Post:
    pontaponta (17th June, 2021)
    Jun 2021
    Thanks reply.
    Pls tell me the pass.
    Jun 2021
    Thanks reply.
    But...
    A long time ago, I used a file using the same software with M5.9.2, but it didn't work.
    I think this file doesn't work.
    Jun 2021
    Quote Originally Posted by Gammoudi View Post
    Thanks reply.
    But...
    Jun 2021
    Quote Originally Posted by kiszka View Post
    Thanks reply.
    Jul 2018
    poland
    Your file......
  10. The Following User Says Thank You to socha1997 For This Useful Post:
  11. #9
    Jun 2021
    Quote Originally Posted by socha1997 View Post
    Your file......
    Thanks reply.
    Is this file for M3.X.X ??
    Should I try this?
  12. #10
    Jul 2018
    poland
    Write my file and you have immo off.....
  13. #11
    Volker's Avatar
    Thanks reply.
    Should I try this?
    M3 / M5 is the same solution.....use file from socha......, disconnect immobox and it will work
    CMD | Alientech K-Tag | Batronix
    +++ NO Passwords +++
    Just press THX & Rep if i helped you....
  14. The Following 2 Users Say Thank You to Volker For This Useful Post:
    pontaponta (17th June, 2021), socha1997 (10th June, 2021)
  15. #12
    Jun 2021
    Thanks,
    I'll try and report.
    regards
  16. #13
    Jun 2021
    Thanks,
    regards
  17. #14
    Jun 2021
    Your file......
    Worked fine !!
    Thanks a lot !!
  18. #15
    Jun 2021
    Worked fine !!
    Thanks a lot !!
