Anyone ever met such problem?
Car came for spare key. No errors on dash runs all ok.
Hooked up few tools no pull pin. That orderred pin ,try program saus wron pin. But pin is ok 100%
So error noticed only in end when tried hook up diag tester to scar for comms.
Just pluged in obd car went crazy,dash full of lights,whhen turn of car ir not turn off dash flickering ,black,but engine not stalhs. Pull out obd plug on runnig car,car shut off. Restarts all ok ,errors goes off. If connect tester back again christmas starting.
Hooked up 3 key tools no such errors. Only with autel
That noticed live voltage low on obd.
Tested 4.5v
Ground pins no ground.
Owner bough car is 2000km from resseler but totaly new . They say no aftermarket instals as resseler took from dealer. But i found non factory wires with fuses under hood,also to bcm.
Video
https://youtu.be/qMMteizQSlk
