Results 1 to 12 of 12
    Jun 2021
    Default A4 b7 2.0 tdi 170 dpff off
    Hello, i just bought an audi a4 b7 170 and the car has a bad dpf off file i think, when i start the car it runs fine, no smoke, but when it warms up the car is start smoking until the temp is about 90, car is pulling and working fine i guess but i want to get rid of the smoke, also the rpm is about 900 at iddle and sometimes is moving from 1000 to 900. Can i have a working dpf off file? and maybe stage 1 if that's possible? Thank you so much.
    File was read with MPPS V16
    CobraRemap's Avatar
    Jun 2021
    Portugal
    Default DPF OFF
    Hello friend , try this DPF - OFF .
    File password in private message.
    Press Thanks and Reputation.
    Best Regards.
  3. The Following User Says Thank You to CobraRemap For This Useful Post:
    fabyfaby295 (20th June, 2021)
    CobraRemap's Avatar
    Jun 2021
    Portugal
    Default DPF OFF FILE FIX
    Try this fix.
    Press thanks and reputation
    Best regards.
  5. The Following User Says Thank You to CobraRemap For This Useful Post:
  6. #4
    Member bendy's Avatar
    Mar 2009
    Essex, UK
    Default try if needed
    Hi fabyfaby295,
    If having problems try this file, your ori file had a lot cut out of it.
    Pass in PM,
    Sorry for hi jack of thread... was replying Saturday morning but CobraRemap beat me to it.. seems may be a problem so posted my map to help if you still got problems.
  7. The Following User Says Thank You to bendy For This Useful Post:
  8. #5
    Jun 2021
    Quote Originally Posted by CobraRemap View Post
    Try this fix.
    Best regards.
    Hello , i just tested the map, and it's good somehow, the car only throws a little bit of smoke when i started then no smoke at all, the problem is when it's warmed up the car shakes when i accelerate, i mean it loses power and start shaking, at iddle it's fine. It shakes when it's below 2300 rpm, after that it's not shaking but still has no power.
  9. #6
    CobraRemap's Avatar
    Jun 2021
    Portugal
    Hello friend.
    What tool did you use to read the ECU and how long did it take to read ?
  10. The Following User Says Thank You to CobraRemap For This Useful Post:
    fabyfaby295 (21st June, 2021)
  11. #7
    Oct 2017
    Quote Originally Posted by fabyfaby295 View Post
    I also had problems with one of his remaps. Making mistakes is okay, but be aware he's rude and calls people childish if someone critism his remap
  12. #8
    CobraRemap's Avatar
    Jun 2021
    Portugal
    Quote Originally Posted by peetr View Post
    Seems i have a weird Stalker.
    IŽll report this issue to the Forum Administrator.
  13. The Following User Says Thank You to CobraRemap For This Useful Post:
  14. #9
    Jun 2021
    Hello, i use mpps v16 and took about 3 minutes to write and read. Bendy gived me a original file which i try it on the car and worked, but it still need a dpf off.
  15. #10
    CobraRemap's Avatar
    Jun 2021
    Portugal
    Glad you managed to solve the problem my friend.
    If you want me to make DPF - OFF , then post the file that worked , and when i return to computer i will modify the file to delete DPF.
    Best Regards Friend.
  16. The Following User Says Thank You to CobraRemap For This Useful Post:
  17. #11
    Jun 2021
    Hello, here it is, also thank you so much everyone for helping me.
  18. The Following User Says Thank You to fabyfaby295 For This Useful Post:
    CobraRemap (21st June, 2021)
  19. #12
    CobraRemap's Avatar
    Jun 2021
    Portugal
    Default DPF OFF .
    Hello my friend , here goes the DPF-OFF File.
    Try it , if the file needs any modification , i will help you to make sure , the car runs ok , no matter how many times it takes , i will help you.
    It is a pleasure to help good people like you , who deserve it .
    I will send the file password by private message.
    If you need my help for other things , feel free to ask , i will help you.
    Best Regards My Friend.
