Results 1 to 12 of 12
    DK Veteran DjRomeoR's Avatar
    Nov 2011
    Garage...
    Default W212 lin bus fault problem
    Hello , have w212 2013-2014year MB and was dault code occupansy sensor short circuit , i tryed 2 emulators and came same fault code :
    U100887 - lin bus 1 short circuit
    And now don’t know how solve , i clear fault but came back , when i dissconect emulator fault code same maybe it’s airbag unit problem ?
    Thank you for help
    fuzz1's Avatar
    Jul 2019
    maybe you should find out when this problem started
    might be a physical problem too.
    or was the airbag deployed
  3. The Following User Says Thank You to fuzz1 For This Useful Post:
    DjRomeoR (26th June, 2021)
    Nov 2011
    Garage...
    Quote Originally Posted by fuzz1 View Post
    Fault code when tested was occupansy sensor short circuit , now this fault never came back, others fault codes when discconect any airbag shows good
    Physical airbag control unit?
    fuzz1's Avatar
    Jul 2019
    was thinking a physical fault with the occupancy sensor or circuit. i really cant understand what you trying to say when "others fault codes when discconect any airbag shows good"
  6. The Following User Says Thank You to fuzz1 For This Useful Post:
    Nov 2011
    Garage...
    1- discconect passenger side airbag
    2- and showing fault code when testing
    3- connect and i can clear this fault
    4- occupansy sensor fault code dont apear anymore ore connected emulator ore emulator off
    5- only left U100887 - lin bus fault code every time
  8. #6
    avital's Avatar
    double post
    Production and development professional IMMOBILIZER/TCU/ESL/ELV/SRS emulators for all brand cars
    PORSCHE / FERRARI / MASERATI / LAMBORGHINI - immobilizer solutions
  9. The Following User Says Thank You to avital For This Useful Post:
    DjRomeoR (27th June, 2021)
  10. #7
    avital's Avatar
    use the oscilloscope to study the LIN line, you should see something similar:
  11. The Following User Says Thank You to avital For This Useful Post:
  12. #8
    Nov 2011
    Garage...
    Tryed 3 emulators and all same , now tryed with xentry coding off sensor mat and seat belt in SRS unit now light srs off , but in passenger seat control unit write what " can ORC message fault " and in this unit i dont find any coding
    maybe someone haved this problem ?
  13. #9
    avital's Avatar
    A few years ago I designed the software of emulator for this system - MB LIN.
    Now it is produced under my license by another company from Poland - company name xxxxx (I will give a link on PM not to be accused of surreptitious advertising of my solutions )
  14. The Following User Says Thank You to avital For This Useful Post:
    DjRomeoR (7th July, 2021)
  15. #10
    Nov 2011
    Garage...
    Solved coded off with star
  16. The Following User Says Thank You to DjRomeoR For This Useful Post:
    fuzz1 (11th November, 2021)
  17. #11
    fuzz1's Avatar
    Jul 2019
    Quote Originally Posted by DjRomeoR View Post
    Did you just disable it in star? Or was the problem solved and then you coded it?
  18. The Following User Says Thank You to fuzz1 For This Useful Post:
    DjRomeoR (11th November, 2021)
  19. #12
    Nov 2011
    Garage...
    No problems this Lin was because is bad emulators and gives Lin fault code.
    Disconnected sensor and coded off with star
    No need any emulators because i try 3-4 emulators and wont work for me so dont use now
  20. The Following User Says Thank You to DjRomeoR For This Useful Post:
