Hello to all. I will have to do a SIRIUS 32 N from a megane 1.6 16v with AC. Do I have to put emulator and what type in ecu after dump modification.
hey!sirius 32 have 29f chip inside,you can immo off the ecu easy(depends if the ecu is kline or can) or put a julie emulator aqnd all good.
port a pic of the pcb and i will tell you if its possible only by file
Ac will continue working no issues
If i Helped you,use thanks and rep button to thank me back
PSAcars (30th June, 2021)
Hello to all. No can chip on bottom corner, so it is k- line. Pic emulator is going to work for this. Yes?
mouh007 (15th March, 2022)
i believe yes.
but also ktag can read these easy.then post file,and immo off![]()
Hello to all. Job done. After software mode and pic emulator car is far away from me.
sevaorama (3rd May, 2022)
Glad you sorted it out mate,that immo off is ok.
No need emulator for K sirius32, also no cheksum calculated, but if car away then good for you
PSAcars (3rd July, 2021)
Hello to all. Thank you for the help, I used a program from here (DK) " sirius 32 real immo off ". What can I use for better results? And ziko I have read somewhere that sirius 32 whit AC need stored immo code to work good, or this is for other can line type?
PSAcars (5th July, 2021)
Hello to all. In this case next time I can use renault decoder tool and cut pin58 and that all?
