Results 1 to 3 of 3
    Jul 2021
    Default Toyota GT86 2017 cluster odometer adjustment
    I have a 2013 Toyota GT86 and I have just purchased a 2017+ cluster as I wanted the new temperature gauges.
    Before swapping my old cluster out I want to make sure the new odometer shows the correct mileage.
    After reading online I saw a lot of people mentioning a 93c66 IC but I cannot find a chip like this on my cluster. (European LHD)
    Am I correct in assuming that the chip I should desolder is S93C86 AKA IC6? (See picture attached)
    I've never done anything like this before, so any tips / information would be greatly appreciated.
    My plan was to use a reflower to carefully heat it up and lift the chip using tweezers from my iFixit kit.
    What would be a recommended temperature? Or should I do it differently?
    USA
    remove chip read as 93c86 x16
  3. The Following User Says Thank You to alexs600 For This Useful Post:
    Nottori (9th July, 2021)
    Jul 2021
    Thanks, I'll try to get that removed.
    Do you know if I have to remove the chip from the old cluster to get a file generated with the correct mileage?
    Or is there a way to get the correct hex code without that?
