Results 1 to 5 of 5
    p1et's Avatar
    Oct 2013
    Default GT10 Iveco ignition decode
    I decoded ignition lock, was unsure in 1 position but generally had 2 pair of cuts:
    1) 2 3 3 4 4 1
    2) 2 3 3 3 4 1
    Only the 1st set was found in instacode so I cut it but they ket doesn't turn, I feel like ignition is very stiff so I assume mu decoding differ really much from original key cut. But I decoded it multiple times and all I got was this and decoding possible only with one direction so mistake of decoding wrong direction is not possible.
    But Im thinking that maybe I should reverse those numbers, I mean 1 might be 4, 2 might be 3 etc. In my Silca Viper and it list cuts from A-D, I assumed A=1
    Anyone have a clue? I want to give it a try because I don't want to strip that stupid ignition with PIN's inside and the door lock is not in good condition so that's why I want to decode it correctly. Ignition picks in 2 mins everytime but decoding seems way off but decoding of all 5 I had straight lined lishi arm so I don't think I can be wrong much...Only 4rth PIN was unsure 3 or 4 but with 3 it doesnt exist in IC but even if it's actually original cut, I should feel a little more of barell movement when trying to turn with all other proper cuts and this one just little off chart.
    Meat-Head's Avatar
    Drill it out, hand customer screw driver add to bill
    premable your paying for insta code, ask them, or time gerses effort how much fir basic key off dealer
    Mar 2018
    UK
    I had problems 2 times with Iveco GT10
    Decoded the door lock and cut the blade
    the blade is perfect on the door also turn the ignition - Start programming and key stop turn the ignition - decode the ignition same like on the door
    this happened to me 2 times both not solved
    I cut them on card 322
  4. The Following User Says Thank You to Manta1600 For This Useful Post:
    p1et (2nd September, 2021)
    rob h's Avatar
    May 2011
    Your blade is to long.
    Take someting from the tip.
    Hold it next to the lishi.
    You will see.
  6. The Following 2 Users Say Thank You to rob h For This Useful Post:
    Manta1600 (4th September, 2021), nazz2 (3rd September, 2021)
    lion0304's Avatar
    Oct 2014
    GT10 i cut with 2mm cutter didn't work. But when i use 1.5mm, blade work perfect.
  8. The Following User Says Thank You to lion0304 For This Useful Post:
