Results 1 to 9 of 9
    Sep 2018
    Stockholm
    Default me17.9.11 pin code
    Hi! need help to find out immo pin from dump
    Thanks!
    Jun 2014
    ankara-turkei
    did you still work in that car ??
    upload ORIGINAL READ FROM ORIGINAL ECU
    or USED ECU READ
    and PUT USED IMMO OFF DUMPS TO USED ECU
    or PUT ORIGINAL IMMO OFF TO ORIGINAL ECU
    not ORIGINAL DUMP TO USED ECU ,or NOT USED DUMP TO ORIGINAL ECU...
    or contact me in whatsapp for fast solution
    Sep 2018
    Stockholm
    Hi! yas! this dump is from donor ecu! and i im try to write original dump to used ecu.. OTP still same.. i cant write full dump back! so im try do immo adapt..
    CarCity's Avatar
    Nov 2016
    Inside my clothes
    Quote Originally Posted by JBoza View Post
    Thanks!
    PIN : 252756
    I surprise those who do not want to use the Thanks and Reputation buttons but ask for the password of the files.
  5. The Following User Says Thank You to CarCity For This Useful Post:
    JBoza (7th September, 2021)
    Jun 2014
    ankara-turkei
    "and i im try to write original dump to used ecu.. "
    this is your fault
    Sep 2018
    Stockholm
    im try yours solution with immo off ! it was firs dump from used ecu and also check after writing same problem ... immo off was not working
    Jun 2014
    ankara-turkei
    mate mate mate....immo off will work..tested may times in my shops or in here too...but you have now 2 x bad ecu...buy NON TOUCHED any same number ecu ,ONLY READ ori dump ,upload here and remind me or any other member can do it for you..
    Sep 2018
    Stockholm
    i have back up from used ecu and i check dump.. its same ! so used ecu same as was !
  10. #9
    Nov 2015
    England
    Hello any one can hepl me decodink PIN for this file ?
