Results 1 to 10 of 10
    Sep 2021
    Default Golf 3 93s56 eeprom adjust
    Hello, I want to adjust the mileage in a gollf 3 motometer dashboard, I was able to read the eeprom (93s56) and calculate the correct mileage with tachosoft,
    but now I don't quite understand what to adjust, there are many numbers but I don't know where to put them, can someone explain this?
    Home
    put you file here
    Keep in mind, English is not my native language.
    Sep 2021
    oke but i dont no (yet) how to post a file.
    also i can read the eeprom in 8 or 16 bit i dont know witch one is the right one?
    Sep 2021
    i have two reads of my eeprom, one is 8 bit the other is 16 bit
    i dont know wich one is ok
    Home
    8 and 16, dont forget write current milange
    Sep 2021
    of the chip i dont know, my car needs 271000km
    other strange ting;
    i have 2 chips from old clusters, one give some miles on the screen of my dash but can't read with asprogrammer
    the other chip give no screen at all at my dach but i can read it with asprogrammer, that is de file i send
    can i change chips or is that not allowed
    Home
    try ....
    • File Type: zip D.zip (628 Bytes, 15 views)
    Sep 2021
    Hello, i still dont get it working, i have new chips (93c56), the 93s56 i cant read out, it say not responding but works in the motometer.
    i write de D.zip file on it (bin file) i solder it back in the motometer and de display says error
    when i solder the original in it its ok (93s56
    i have a motometer sw5.1
    can someone help me wit a bin file with 275000 km's?
    thanks a lot
    Home
    try this
    Post picture of dash. Is your dash Motormeter or VDO?? Which plug white or gray??
    This is for motometer dash sw4.0-6.0 1991-1996 model year golf 3
    The mileage is stored in the next lines:
    0000: 0E 12 05 60 0F 12 05 61 10 12 05 62 11 12 05 63
    0010: 12 12 05 64 13 12 05 65 0D 12 05 50 0E 12 05 51
    0020: 0F 12 05 52 10 12 05 53 11 12 05 54 12 12 05 55
    0030: 13 12 05 56 14 12 05 57 15 12 05 58 16 12 05 59
    where the next bytes:
    all shown bytes is a mileage
    past this into dump to get 275000km's:
    0E2750000F2750011027500211275003
    12275004132750051427500615275007
    16275008172750090F27501010275011
    11275012122750131327501414275015
    eeprom 93c56
    IIRC this dash can be done through service plug if the car is pre obdII.
