Results 1 to 7 of 7
    Aug 2021
    Planet earth
    Default I need help with My J-link V9
    HI
    Are there any J-link experts here
    Keep getting these errors
    Could not perform target reset
    failed to connect
    could not perform custom int seqence
    RAM check failed @ addr 0x00202000
    Aug 2021
    Planet earth
    Hello All
    Please All
    What do you want to do ?
    I'm not an expert but you may ask questions in Segger forum. Do you go by J-flash or J-link commander ? Quite a lot of setting may need, target resetting is one of the concern and much possible to mcu specific.
    Aug 2021
    Planet earth
    Quote Originally Posted by Zmann View Post
    Thanks for the reply
    I want to be able to read the firmware from a chip on another board connecting using SWD
    I believe that I have been sold a J-link clone rather than a orginal / genuine
    I have asked on the segger forum but no responses
    I have seen allot of people using J-link here for automative purposes so i thought i would ask here
    I have a J-link V9 with a stm32f205rgt6 inside
    I have used the latest J-flash and old versions
    Which version is the best for such clone ?
    I dont have any development boards to try the J-link on but I do have a J-link V8
    So I thought I would try and read the V8 frimware using the V9 as a test and once it works I know the J-link is working I can work on reading the firmware from the other board
    I keep getting the following errors
    failed to connect
    Please help
    Thanks all
    You have a long good post but missing to say what your target is. And missing to answer on how you did read, by "J-flash or J-link commander"?
    RAM check failed and so on is mainly caused by the target was not stopped/halted properly even the J-link says it has been connected, or with wrong address setting.
    I'm not sure your device part number is exactly in the J-flash device list, you may read more on Segger's UM08001 - J-Link / J-Trace User Guide section "7.10 Reset strategies" and adapt the settings to your device under Options/Project settings/MCU/Init. step (this is J-flash environment).
    edit: my bad read, you used J-flash. So, my suggest would be applicable !
    Aug 2021
    Planet earth
    Is it possible you can help me more to fix this please
    Aug 2021
    Planet earth
    The target board is a board from an AV receiver with a TMPM361F10FG
    but to see if the J-link is working I wanted to read the firmware on a J-link V8
    The V8 has a AT91SAM7S64 and the V9 has a ARM 32F205RGT6
    Is there any way to un-brick these and flash new firmware
    I have used the firmware update using the J-link tools but not sure if it has bricked these
