Results 1 to 15 of 17
    Oct 2016
    Default BMW E46 starting problem after cloning EWS3
    Hi everyone
    I have problem with BMW E46 from cloning EWS and now the car turns the engine but does not start. Unfortunately I do not have the car here and the workshop that I commissioned this job does not have adequate diagnostic equipment to synchronize DDE / EWS. Before sending the EWS I checked the two keys in the bank with an ews test rig and everything seemed correct.
    Could someone tell me if it is possible to sync DDE / EWS without having the car. I attach the original ews reading in case someone can review the file
    EWS reference: 6135 6 905 669 HW03 SW8
    kiszka's Avatar
    Quote Originally Posted by daten View Post
    Hi everyone
    you have the eeprom reading of the old EWS
    Oct 2016
    You mean reading EWS donor (new)?
    If I have, I attach the file
    pioneer427's Avatar
    Feb 2017
    Belarus
    Hi everyone
    Try this
    Ign ON
    WAIT
    ign OFF
    WAIT
    Start engine
    Pass in pm
  5. The Following User Says Thank You to pioneer427 For This Useful Post:
    daten (19th October, 2021)
    pioneer427's Avatar
    Feb 2017
    Belarus
    Your pm is full
    V.I.P. Master of the IMMO
    lupu_sandu's Avatar
    Far far away
    I'm thinking that you don't reset rolling codes from keys.
    Test this one, no pass.
  8. The Following User Says Thank You to lupu_sandu For This Useful Post:
    daten (20th October, 2021)
  9. #7
    pioneer427's Avatar
    Feb 2017
    Belarus
    The engine crank , it means the keys are ok
  10. #8
    Oct 2016
    Quote Originally Posted by pioneer427 View Post
    Your pm is full
    Please can you send me the password
    Thank you
  11. #9
    lupu_sandu's Avatar
    Far far away
    I read wrong 1st post.
    What ecu you have in the car? Without eeprom from ecu (for example i cannot sync petrol cars) will be pretty impossible to mare "ready to start" your dumps
  12. #10
    Oct 2016
    Quote Originally Posted by lupu_sandu View Post
    The engine ECU is Bosch EDC15M but I have no eerpom reading
  13. #11
    kiszka's Avatar
    if it's not a problem for you, check my file
    original keys should work
    https://mega.nz/file/wqJ0FbKT
    if you haven't tried doing the sync then the car should work
  14. #12
    Oct 2016
    Hi everyone
    Thanks for your help! The car started.
    Synchro by obd with bmw scanner.
    Too bad I couldn't test the files, but next time.
    Greetings
  15. #13
    Sep 2018
    poland
    Hello, please help me. Bmw7 e38 2000r 3.0 diesel bosch edc15 0 281 010 314, 7 788 016, flash am29f400.
    Bmw no crank, ews3 - dde, error not synchro. Will anyone read pin /ISN - flash 29f400.
  16. #14
    kiszka's Avatar
    Quote Originally Posted by adielektro View Post
    isn is in eeprom 95p08
  17. #15
    Sep 2018
    poland
    ok, i will read and insert
