Results 1 to 10 of 10
    Col19's Avatar
    Jan 2019
    France
    Default Saab 9-3 Pin Help Please !!!
    Hi friends
    I am bothering with a Saab 9-3 2.2 Diesel model 2003, the ECU is out of order.
    At first I tried to change the IRL2909 transistor but unfortunately without result.
    I would like to change the ECU with the injection pump but cannot read the pin code to fit a new injection pump ECU.
    I am not Tech2 or GM-MDI but several J2534 device, if an experienced friend has a tip please share.
    Thanks in advance.
    Mar 2018
    UK
    try this code - 4ACM
  3. The Following User Says Thank You to Manta1600 For This Useful Post:
    Col19 (14th November, 2021)
    Col19's Avatar
    Jan 2019
    France
    Hi dear friend Manta1600 thank you very much for your help, I am looking for pump and ecu, I will try your sharing I hope this code will be ok, I will share the result as soon as I find and try the new one ECU, my respects for you dear friend Manta1600, I wish you a long happy life.
    Col19's Avatar
    Jan 2019
    France
    Hi friends Back i just found an ECU to replace mine, i can't read the pin code, i need to reset but i need the pin, please one last help finding the pin correct.
    VIN: YS3FD45D831063890
    Thanks in advance and respect to you.
    p1et's Avatar
    Oct 2013
    Quote Originally Posted by Col19 View Post
    PIN code for this VIN: EH5Y
  7. The Following User Says Thank You to p1et For This Useful Post:
    Col19 (6th December, 2021)
  8. #6
    Col19's Avatar
    Jan 2019
    France
    Hi dear friend p1et
    Thank you very much, I will not forget, I wish you all the best, I am at your disposal, thank you very much.
  9. #7
    Col19's Avatar
    Jan 2019
    France
    Hi friends
    I had bought a PSG16 ECU to replace mine, but the damn pump number is not compatible.
    I still buy an ECU with full pump, try to read the pin with fvdi but impossible, I change the VIN with the original VIN and I get the error P1614 due to the pin code
    This is why I once again need the pin to adapt it. I apologize for the inconvenience, long happy life to all members.
    Thanks for understanding.
    SAAB 93 2.2 TID (13/11/2008)
    NIV : YS3FF45D231009088
  10. #8
    p1et's Avatar
    Oct 2013
    PIN Code: 2K7R
  11. The Following User Says Thank You to p1et For This Useful Post:
    Col19 (13th December, 2021)
  12. #9
    Col19's Avatar
    Jan 2019
    France
    Hi dear friend p1et
    I apologize for disturbing you
    I wish you all the happiness
    Thank you very much for your understanding
    I will never forget you, I am at your service, my respects for the King p1et
  13. The Following User Says Thank You to Col19 For This Useful Post:
    p1et (13th December, 2021)
  14. #10
    p1et's Avatar
    Oct 2013
    You're welcome my friend and thx
  15. The Following User Says Thank You to p1et For This Useful Post:
